air bags in rear suspension?
i read somehting about putting airbags in the right rear spring, and i noticed that some of the spnsors carry them. could someone explain to me the importance of this? im guessing it helps with straight line launches, but will it help/hurt cornering? thanks!
Taken from Thunder Racing site.
"On a rear-wheel-drive car, engine torque creates a twisting effect which presses down on the left rear and right front wheels creating a corresponding lift on the rear rear and left front. Every drag racing fan has seen this body twisting action as a car leaves the line. This lift on the right rear results in it doing less work since there's less weight and consequently it will spin the right rear more than the left. To get maximum possible forward thrust, both tires must be equally loaded. Pre-loading your suspension with a set of drag bags air springs evens up the loads between the two wheels to achieve maximum potential forward thrust."
That pretty much explains it. I can't see why it would hurt cornering.
