ABS + TRAC OFF + BRAKE light!!
None of it will work when you remove the whole module, I'd advise fixing it if you care to keep ABS/TCS.
Our kits are designed to completely remove the whole setup, replacing the module and bracket with preformed lines and adjustable proportioning valve so that you can bias front/rear brakes.
