Modifying Your Front Upper Shock Mount
I'll need to look at some of my IAS photos to make sure it will work properly. It's a very unique unit.
BTW, how do you like those shocks? Handle good and ride good?
Just don't install any large diameter, heavy duty washers on it. Do you know what I'm talking about?
I've been really happy with the IAS shocks; they ride great considering the 600 lbs.in. springs up front, and handling is equally impressive!
The rear IAS shocks also mount upside down and seem to work really good with my airbags.
If so, just leave them off. Otherwise they will be pressed against the outer metal ring in the 3rd pic of post 3 and prevent the shock from tilting.
The left is from a GlobalWest kit, and the right came off some koni's.
I just posted the pictures for others that don't know exactly what your talking about..
Let me show my pix of my 2001 Camaro front Koni shocks and G/C+Ecb..
I did measure 2" down from 28". There still plenty room for turning left and right suspension.
Should I go ahead do it on it?
Are you worrying about the extension?
What is your ride height at?
What is the 28" your measuring?I measured height>from floor to that top line fender..
Are you worrying about the extension? No really,
I impressed of your posts about it. It makes me tempt to do it.
I am "sort of" afraid if I do it working on strut mount same as your idea and would ruin on my strut mount..
I work on my 2001 Camaro for road course weekend and car show.
I hope so this post would you understand better.
Thank you for take your time.
Tell you what. Have the car sitting on level ground and measure the fender lip to rim lip exactly, then take a jack and lift the car until the wheel is fully extended. Now measure the same two points.
The shock only allows 6" of travel, so if your wheel dropped 3" your right in the middle and probably don't need to do it.
If your wheel dropped 4", then it means it can only compress 2" and that's not very much. Doing this modification will give you back an inch+. That will noticably help things. Just get some packers first, so you can limit your travel just in case something rubs.
Tell you what. Have the car sitting on level ground and measure the fender lip to rim lip exactly,25.5" then take a jack and lift the car until the wheel is fully extended. 27.5" Now measure the same two points.
The shock only allows 6" of travel, so if your wheel dropped 3" your right in the middle and probably don't need to do it. 4" suspension travel.
If your wheel dropped 4", then it means it can only compress 2" and that's not very much. Doing this modification will give you back an inch+. That will noticably help things. Just get some packers first, so you can limit your travel just in case something rubs. True...
Look at #27, I measured from floor to fender lip.
Anyway, your numbers just don't make sense. Are your saying the wheel can only extend 2" from ride height? (27.5 minus 25.5)
Or does it drop 4"?
