Modifying Your Front Upper Shock Mount
You can always squirt some water proof grease in the hole , then put a piece of tape over it.
Regardless, I would still recommend coating the inside of the upper mount, the isolator, and the shock shaft from where it goes into the upper mount on up with something like the clear waterproof grease you put on poly bushings.
I feel like stupid LOL. I like the idea of putting bushing grease. I'll make a note of it.
I'm considering doing away with the factory mount and replacing it with a rod end.
I just read the first and last pages... Looks like a great walkthrough of the process.
I did have to clearance the shock tower on mine, on account of the shock rod sticking higher up into it.
If your using a Koni shock, you can unscrew the tophat and screw on a rod end style tophat which Koni sells. It even has the adjustment window in it, so it is very easy to do and won't void the shocks warranty.
Click on the thumbnails
Here is how you can modify ANY shock to a sperical bearing.You buy a kit and then weld the main cylinder to the top of the shock rod. Then the bearing slides in and is held in place by snap rings.
I'm also working on an aluminum drop spindle conversion which reduces the ride height 1.25", reduces unsprung weight, maintains the ABS and will do away with the shocktowers. It's pretty complicated and unfinished so I won't go into details here.
A started a thread already on the spindle swap.
https://ls1tech.com/forums/suspensio...t-spindle.html
I wanna know what exactly need to be done to the top mount. Also, according to your pics, did the shock travel being reduced?
You can then put the bearing higher or lower than the stock location. You can mount it as high as the hood if you want. You would just cut a big hole in that upper control arm piece so you can mount the rod end higher.
This is a picture of a sperical bearing mounting kit welded to the top of a coilover shock and then gold anodized to prevent corrosion. See how the bearing is held in place with snap rings?
You can also take the bearing and turn it sideways. This is often refered to as a "pillow ball mount".
I'm trying to decide whether a metal bearing or a polyurethane bushing would be best for me. The big advantage for me is the ease of removing the shocks. Right now you have to undo the 8 shock tower bolts, 2 master cylinder bolts, 2 ABS bolts, 4 lower shock bolts and finally the 2 stud bolts. I want to change this to only 4 lower shock bolts and 2 upper shock bolts. So from 18 bolts down to 6.
Are there any modifications available for the rear? I like the idea of doing this mod and cutting the springs for a nice 1" drop that won't cost a fortune and should drive very smooth. Would the rear just bottom out if the rear springs were cut to lower the car 1"?
I wonder what it would take to get my bilstein hd's to work. I'll try to take a look and post results.
