Modifying Your Front Upper Shock Mount
Here's the base setup
The upper shock mount serves many functions. Mainly it holds the spring and shock as a single unit. The inner portion of the mount is the part we are modifying and the outer part of the mount stays the same.
Since the spring part is uneffected, the ride height is uneffected.
You gain that extra compression travel by taking it from the extension side.
Once you do this mod, your wheels will no longer hang down as far when you jack up the car body. Which to me is a bonus. For instance, you won't have to jack the car as high up to change a tire.
Thanks
Thanks
The steel sleeve the shock bolts to is held in place by only the rubber. So it CAN be removed, but I don't know if the monoball would be small enough to fit in it.
What shock are you using (Koni?) and what are you trying to accomplish?
Ideally I'd like to get rid of the upper rubber mount all together, but I kinda got ahead of myself and forgot that the stock sping isn't flat so simple cup up top probably won't be enough to locate the factory style spring. So I was thinking of a way to core out the center of the rubber mount, then slice off enough of the factory style mount so use so the spring is located and go from there. But the more I look, the more I feel like it would be overly complex. I figured you have done enough work with the shock mount to know if this is even possible.
So why do you want to stick with the factory style springs?
Have you considered how your going to insert the bolt for it? Your almost sure to need the spring below the ball so it's not in the way.
I would either leave it stud mount or else go all the way and buy a coilover conversion for the front (threaded sleeves and collars) and then do the monoball mount. I've had a coilover conversion on my car for about 5 years and they are great. You can fine tune the ride height to exactly how you want it.
) So that led me here. I'm not trying to reinvent the wheel or rewrite the laws of physics. If its more trouble than its worth, I end up with a set of monoball tophats in my parts bin. No big deal.I could just go to a coil over deal up front, but the strano package is nice and I'm very happy with it. I just didn't totally think this one out before hand.
So am I heading down a one way street or is this worth pushing forward?
Your current setup is fine. If you want to upgrade it, I would suggest saving for a front coilover kit ($225 I think, maybe less, including same rate springs that you have now) and then use the monoballs to do away with old mounts. Sell your Strano front springs to make up the cost difference.
Lets say you machined an upper spring perch to ride below the monoball hat, what would that do to the operating range of the spring/shock?
Something like in the pic, but made to fit the factory style spring? (Not my idea, but taken from a post on frrax)
