Yamaha Generator EF2600 $600
$600, these are $1,100 new. Its a 2006. Used it like tewo times. Here are the specs.
Type Brushless
Maximum AC Output 2600 watts
Rated AC Output 2300 watts
Rated / Maximum AC Current 19 / 21.6 amps @ 120V
Engine Air-Cooled, Four-Stroke, OHV Single Cylinder
Displacement / HP 171cc / 5.5 hp
Overall Length 20.1"
Overall Width 16.3"
Overall Height 16.7"
Dry Weight 90 lbs.
Fuel Tank Capacity 3.2 gallons
Continuous Operation at 1/2 Rated Load 11 hrs.
Noise Level 67.0 dBA
4-stroke, OHV (overhead valve), single cylinder, air-cooled engine - Improved efficiency, increased reliability and quiter operation.
Auto-decompression system - Reduces compression for easier starting.
AC Voltmeter - Provides easy-to-read voltage output.
Oil watch warning system - Prevents engine damage, avoids costly repairs and minimizes down time. Provides added peace of mind and enhances long-term durability.
AC Non-fuse thermal breaker - Peace of mind and added durability.
GFCI (Ground Fault Circuit Interrupter) - Shuts down the power when a fault to ground is detected.
Fuel gauge - Ability to gauge fuel level without opening cap.
Large 3.2 gallon fuel tank - Provides 11 hours of continuous operation @ 1/2 rated load.
Rugged full rollover frame - Added durability and protects generator engine and fuel tank.
Mechanical governor - Maintains engine speed to deliver consistent AC output.
Specially designed muffler - Reduces weight and noise.
Brushless alternator - Maintenance free and reliable.
Rubber vibration isolation mounts - Reduces vibration and increases smooth operation.
Cast iron cylinder lining - Long engine life, excellent heat dissipation
Type Brushless
Overall Width 16.3"
Dry Weight 90 lbs.
