120hp Progressive Direct Port Nitrous Kit w/ all acc.
Progressive, Direct port nitrous kit for sale. Kit is jetted for 120 shot. Everything you need to install and run on a LS1. Custom direct port with Nitrous Express distribution block and NXL nozzles. Nozzles install under injectors. Nitrous Express fuel, nitrous and purge solenoids. Enough purge line to run a dual purge out the front, rear, or heat extractors of the hood. Dyno Tune 10lb bottle with heater, 860 spare tire trunk mount bottle kit, braided blow down tube, Trick Performance Progressive gauge controller, TPP-00019. The gauge has inputs and programmable cutoffs for a wide band sensor, tachometer, throttle position, and a pressure sensor. Also included are Nitrous Outlet’s '98-'02 F-Body Ash Tray Switch Panel, nitrous pressure and fuel pressure sensors, all nitrous lines, and all relays necessary. An extra relay and resistor that can be wired into the IAT to pull timing when the system is armed is also included. As well as a NX remote bottle opener. I don't want to separate. $1300+shipping. I'm in Longview, Tx.
Last edited by TKhawk01; 12-16-2009 at 01:46 PM. Reason: added shot size and blow down tube
You wire the relay into the intake air temp wire so that when you trigger the nitrous the resister makes the car think the air intake temp is 133 pulling the timing. There is a diagram in the nitrous section, I'll find it and post it here for you.
