still got the tourque arm? Will this fit right in with my moser 9" and t56? any adjustments I have to make?
I believe it will fit but you should check ahead of time. If a stock torque arm bolts to the Moser 9" then it will fit this one, as it's a stock replacement. Also, it's adjustable so you can adjust the pinion angle. This is important especially if you're lowered.
I would buy the relocation cross member as well to take the load of the transmission tail shaft and adjust instant center for best traction.
