LSK/XER Cam and springs, Nitrous LS6/1 plate kit, Stock Alum DS, 31 spline slip yoke
Selling a few things here, in need of cash. Located in NW Houston, prefer pickup. I can also ship if needed. I can also get pics later this weekend.
Starting off with a Comp LSK/XER cam. The Cam only has dyno time on it, previous owner decided to go with a bigger cam for the build. Looks like new.
-243/248 @ .050 .654/.615 lift with 1.7 rocker 111+1 LSA $275
-PRC EHT .675" Springs. New in Box, never used. $335
-GM LS2 Timing chain, New in Bag, never used. $35
-Nitrous Kit has only been sprayed twice according to previous owner. It consists of :
Nitrous Outlet LS1/LS6 plate with jets. It goes for $230 new.
Cold fusion LS1 kit. Up to 200hp, Cold fusion bottle with mounting brackets bottle nut and gauge, blanket, 15ft 4an feed line, the misc relays, WOT switch, etc.
Retails for $470 new
http://www.coldfusionnitrous.com/Wet...?CategoryID=37
Automatic Bottle Heater $150 new
BMN Nitro Control Window Switch
$500obo
-Stock Aluminum Driveshaft good shape with Unknown slip yoke. Its a big 31 spline with the splines starting half ways down the yoke.
$80
-Dennys Driveshaft Forged 31 Spline Tremec slip yoke. Ordered this a long time ago without knowing what I needed. Its new in box also, never used. 95 bucks new,
http://www.dennysdriveshaft.com/p328...1_splines.html
$60
$500obo
$80
$60
GRIND # LS1 2131R /3734R HR111+1
DURATION @ .050 INTAKE 243 ROCKER ARM RATIO 1.70
DURATION @ .050 EXHAUST 248 ROCKER ARM RATIO 1.70
LOBE LIFT INTAKE .3850
VALVE LIFT INTAKE .654
LOBE LIFT EXHAUST .3620
VALVE LIFT EXHAUST .615
LOBE SEPARATION 111.0
DURATION .006 INTAKE C/L 110.0
TAPPET LIFT INTAKE 293 CAM ADVANCE 1
TAPPET LIFT EXHAUST 297 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
JOURNAL DIAMETER STD 2.165
VALVE OPEN INTAKE 11
VALVE OPEN EXHAUST 56
VALVE CLOSED INTAKE 51
VALVE CLOSED EXHAUST 12
INTAKE LOBE ID 2131R / EXHAUST LOBE ID 3734R
