6.0,l92 heads and more
CALL OR TEXT 512-426-1453
90k LQ9 6.0L shortblock. Pistons are flycut .060 for a big cam,installed arp rod bolts, new gm hd timing chain and brand new ls7 lifters. Has a modifed oil pan and pickup tube with has had 1 1/2 taken off the bottom for ground clearance. $1000.00 {DOES NOT INCLUDED WATER PUMP OR PULLEY
02 T56 complete 70k $1000
L92 heads with rocker assembly, sold the stock heavy valves. Replaced them with brand new gm ls3 hollow stem intake valves and rev stainless steel 1.60 exhaust. The have brand new lunati gold .660 lift springs on them with all new hardware. The heads have also been milled .030 . $1000.00
Patrick G custom grind cam. XFI 232/238 112+2 .612/.607 $250
ls1 meizere electric water pump without heater. $300
comp cam pushrods 7.375 new in box $100
new slp underdrive pulley $150
new jantzer performance 92mm tb $300
autobond power roll bar for 79-93 mustang $150
Camaro RAD assembly $150
LS7 clutch assembly with flywheel $250 2k on it.
wit
wit
