700 HP Big Block Chevy
This motor is out of my sisters racecar. It was built to turn 7000 + RPMS, but they had the car shifting at 6600 rpms. The car was never setup to take full advantage of this motor. They had a 31" tall slick with a powerglide/3.89 gear and the car went 10.02 with a weak 1.6X 60'. I believe this motor could push a 3000lb car high 9.9x's (or better) as her traps were high 13x's/low14x. She won all her races on the big end. She only ran the car 1 season and with that setup and it was never pushed hard.^$6800
700hp 460ci
Motor Build Sheet
• 461 Cubic Inch
• 454/30 Over
• LS6 Black 4 bolt
• ARP Main Stubs
• ARP Head Stubs
• Nitrated steel crank shaft
• 7/16 dimple rods with ARP wave LOC 2000 rod bolts
• Upper End bronze bushing
• Stef Aluminum oil pan
• TRW 13.3 to 1 pistons
• Lower end is balanced
• ATI Super dampner harmontic balancer
• Jessel belt drive
• Erson roll camshaft
• Comp cam roller lifters
• Dart 320 cylinder heads –aluminum upgrade for higher cam shaft
• Reher and Morrison push rod
• Enduro crane gold rocker arms
• R&M stub girdles
• Moroso Valve covers
• Edlebrock 454R victor dominator intake
700hp 460ci
Motor Build Sheet
• 461 Cubic Inch
• 454/30 Over
• LS6 Black 4 bolt
• ARP Main Stubs
• ARP Head Stubs
• Jessel belt drive
• R&M stub girdles
