RAM RTrack 10.5 Twin Disk Clutch *PICS*
Call Kolt at 214-808-1334 with any questions.
$600 +shipping
Ram 10.5 RTrack Twin Disk Clutch for LS1 Fbody and C5. Ram Part# 90-2100N
Also comes with ARP Flywheel Bolts.
Has about 1500 miles on it and felt great on the street while being used. No longer have car anymore so I need to sell this clutch.
RAM WEBSITE ON RTrack 10.5:
"The RAM RTrack Dual is modeled after our highly successful drag racing clutches used in high horsepower Pro Stock and Pro Modified applications. The major difference between these clutches and the Force 10.5 is the floater drive system. RTrack Dual uses a stand driven floater plate, which provides higher torque capacity and negative load capacity for vehicles that see more use at the track. It uses a 2400 pound clamp load pressure plate for good holding power without excessive pedal effort, and features 300 series sprung hub top disc and solid hub bottom disc for smooth engagement. A 900 series disc version is available for higher torque load applications up to about 1300 foot pounds. Expect some floater plate noise at idle with this unit’s drive system. If you need the ultimate in holding power and durability for street or strip, the RTrack Dual is for you!"
![](http://i148.photobucket.com/albums/s40/kkkustoms06/clutchfront.jpg)
![](http://i148.photobucket.com/albums/s40/kkkustoms06/clutchopen.jpg)
$600 +shipping
![](http://i148.photobucket.com/albums/s40/kkkustoms06/clutchbolts.jpg)
