2 - 12 inch Rockford Fosgate POWER HX2's
If you know about these subs, you know they are monsters and will hold pretty much any amount of power that you can throw at them.
These are the older Power HX2’s(the good ones, before Best Buy started carrying their products).
Each sub is rated at 2,000 watts and each sub is constructed with a 300oz magnet.
The subs are dual voice coil and are 2 ohms per coil(meaning you can run two amps with either a 1 ohm or 4 ohm load, or one amp can run both at a 2 ohm or 8 ohm load).
The subs are in perfect working condition and I still have the boxes for each subwoofer.
I am located in Hurst, TX and I am asking $450 for both.
I will be somewhat flexible in my asking price.
Thanks for looking!
Manufacturer: Rockford Fosgate
Model Number: RFR3112
Weight: 38 lbs
Magnet Size: 300 oz
• Peak Power Handling: 2,000 watts
• RMS Power Handling: 1,000 watts (500 watts per coil)
• FIBERlock treated paper cone with Santoprene™ rubber surround
• Frequency Response: 26-400 Hz
• Sensitivity: 85 dB
• Dual Voice Coil Design (two 2-ohm voice coils)
• Top Mount Depth 6-7/8"
• Sealed Box Volume: 1.00 cubic feet
• Ported Box Volume: 1.75-4.0 cubic feet
Thanks for looking!
Weight: 38 lbs
Magnet Size: 300 oz
