COMP Cams 7638-16 Magnum Pushrods LS1 LS6 5/16" x 7.400"
$60.00 Firm Shipped. Has about 3500 miles.
![](http://www.ls1gto.com/forums/attachment.php?attachmentid=131840&stc=1&d=1292538463)
COMP Cams Magnum Push Rods #7638-16
•5/16" Diameter
•7.400" Long
COMP CAMS MAGNUM PUSHRODS
COMP Cams Magnum Pushrods are the perfect complement to your Hot Street, Bracket, Oval Track, or any other high performance engine. Magnum Pushrods are one-piece .080” wall chromemoly steel. These pushrods are an affordable alternative for engines needing a pushrod to stand up to higher spring pressures and the associated stresses of a high performance engine. All Magnum Pushrods are Heat Treated to be compatible with guide plates.
•5/16" Diameter
•7.400" Long
