Texas Classifieds Sell your items and vehicles here in Texas
Built 2000 c5 coupe - spring/Houston
Old Sep 6, 2012 | 12:26 AM
ragu1585's Avatar
Default Built 2000 c5 coupe - spring/Houston
2000 vette. 994XX miles on body. Driver seat has a small tear from before I purchased it. Purchased locally with around 90K miles 3+ years ago.dum Passenger seat looks pretty new, both seats have plenty of cushion. Both power seats. Good tags and inspection. Front bumper needs paint from rock chips. Rear bumper needs paint from careless drivers bumping the corner. Bottom rear fascia is painted black. All lights painted or tinted black. Rear corvette flags tinted black. Z06 front grill screens up front and HID 6000 headlights.dum Black seats w/ torch red (lower door sills and panels, glove box). Loyd's driver/passenger logo floor mats.dum Kool mat & dyno mat insulation (entire interior).
Iron block (gm6.0L) 408 (eagle 4.00 crankshaft, 24x tooth reluctor, eagle 6.125 H-beam rods, diamond forged pistons 4.010 bore, 4.000 stroke, flat-top -2cc valve reliefs) all ARP hardware.
Afr 205 heads with arp head studs
239/255 624/624 114 comp cam
Ls7 lifters
dual valve springs
Fast 90 intake
LG G2 90mm throttle body
Halltech stinger bridge/cold air
C5Zo6 85mm mass air
Asp underdrive pulley
Highflow oil pump
Bosch 30 lb injectors
Yellowtop Optima battery (01/12)
Walbro fuel pump
160 degree thermostat
Lg pro series SS longtube headers w/ V-band collectors
LG 3in X pipe no cats
Corsa indy's catcack w/ tiger shark tips
Built 4L60E
3600 triple disk circle D converter
B&M tran cooler w/ steel braided lines to the trans
DTE trans/diff brace
Refreshed/rebuilt rear diff with new seals, hardened 300mm shafts and 3.15 gears.
Less then 1k miles on transmission and differential (done at the same time).
Steel braided brake lines on all 4 corners
New (less then 1k miles) on drilled rotors and hawk pads on all 4 corners
1k miles on rear continental tires
Used nt05 front tires
OEM c5zo6 rims
Lingenfelter mini tub for 12-13in rear rims
Custom fiberglass sub enclosure (12's)
With covers for amps (2 amps one for subs one for mid/highs) in the cubby holes. Image dynamic high and mids in the doors and subs also.
Cons: needs painted front and rear bumpers, driver side head light cover needs fixed (functional), center console lid needs replaced (functional), passenger side mirror needs paint work, and hvac and heads up displays are dim. car needs a final tune now that the break in is finished on trans, but still drives shifts idles good, smooth!
I did my best to list everything off the top of my head but I may or may not have left something out.
NO JOY RIDES, NO TIRE KICKERS, MOTIVATED SELLER, SOLD AS IS
http://houston.craigslist.org/cto/3253186284.html
Old Sep 6, 2012 | 08:15 AM
Blackfly's Avatar
Someone is saving for a C7!
Old Sep 6, 2012 | 08:34 AM
ragu1585's Avatar
A c6 coupe or GS Someday would be just fine with me
Old Sep 6, 2012 | 08:38 AM
Quick's Avatar
dum = dumb?
Old Sep 6, 2012 | 04:26 PM
ragu1585's Avatar
Awe chit. I coppied and pasted from my email. Dont know why it did that after each <enter>. Thanks for the bump
Old Sep 8, 2012 | 03:15 AM
ragu1585's Avatar
Stupid iPhone autocorrected my title to ic!! Dammit oh well bump
Old Sep 10, 2012 | 07:54 AM
ragu1585's Avatar
Monday morning!
Old Sep 11, 2012 | 02:13 AM
ragu1585's Avatar
Old Sep 12, 2012 | 12:00 PM
ragu1585's Avatar
Pics added
Old Sep 15, 2012 | 11:20 PM
ragu1585's Avatar
Converter info updated! Bump
Old Sep 16, 2012 | 01:26 AM
slvr T/A's Avatar
I've seen this vette around Spring, super clean and sounds awesome!
Old Sep 16, 2012 | 08:51 AM
ragu1585's Avatar
Thank you sir
Old Sep 16, 2012 | 10:57 AM
08-4door's Avatar
Bump for nice car and good seller.
Old Sep 18, 2012 | 12:21 AM
ragu1585's Avatar
Thanks jack. What's good??
Lots of trade offers unfortunately I need a buyer so up it goes
Old Sep 22, 2012 | 02:26 AM
ragu1585's Avatar
Negotiable but not looking for trades unless it's $$$
Old Sep 29, 2012 | 10:12 PM
08-4door's Avatar
Thought this would of sold by now...free bump..
Old Oct 12, 2012 | 06:19 PM
ragu1585's Avatar
Entertaining Offers
