Texas Classifieds Sell your items and vehicles here in Texas
Built 370 shortblock $2000 firm
Old 05-09-2014 | 11:13 AM
LTX355's Avatar
Default Built 370 shortblock $2000 firm
I have a 370 shortblock built from truck 6.0 iron block. Diamond forged 11510 pistons with 2cc valve reliefs, Callies 6.1 compstar H-beams with arp 2000 bolts, Stock gm ls1 crank, CS2010-35 piston rings gapped for a mild 150-200 hit. Or mild boost. Clevite crank and rod bearings, durabond cam bearings. Engine block was machined at Houston Engine & Balance. Rotating Assembly balanced by Jeff. Has gone 12.20s @ 110 in my truck with a mild cam, stock ls3 heads and intake through 4l80e. Still needed some tuning. Pictures are of new stuff the shortblock has around 500 miles and 6 passes down the 1/4 currently. It is still in truck but the heads are currently being ported @ TEA. If it sells I will pull it for the new owner. If it doesnt then I will bolt heads back up and shoot for 11s on motor. Engine has not seen any nos yet. I was waiting to get to the 11s before spraying it. Asking 2000 firm for the shortblock. I stay in Baytown next door to Houston if someone is interested text me @ 2816913154
Attached Thumbnails Built 370 shortblock 00 firm-img_62027581645194.jpeg   Built 370 shortblock 00 firm-img_62068209941092.jpeg
Old 05-11-2014 | 07:22 AM
Chillipepper/gto's Avatar
What compression did it have, and what CC was the heads.
Old 05-11-2014 | 07:52 AM
Also what's the max rwhp rating for this motor
Old 05-11-2014 | 12:55 PM
ZONES89RS's Avatar
In-Zane Moderator
There is no max HP rating for a motor. Being forged it will take as much as the ring gap can handle. The stock crank wi handle as much as the pistons and rods. I would say, if the gap was opened up, it would take 1000 HP easily.
Old 05-17-2014 | 08:26 PM
LTX355's Avatar
Sold!
Quick Reply: Built 370 shortblock $2000 firm
