Built 403ci LS2 and Built 4L70e w/Stall
SOLD!!!!
Built 403ci LS2 out of a TBSS
Eagle 4" stroke crank 58x reluctor
Eagle H-Beam Rods
JE Pistons, 11.2cr
ARP Main studs, ARP rod bolts, ARP Head studs
XHP 317 Heads, intake runners flow 318CFM@.650
Comp trunion upgrade on rockers
Engine originally built for boost but currently has NA cam
LS7 Lifters
Trick-flo pushrods
Truck pan
ASP Underdrive pulley
Full set of truck coil packs and truck TB
Can be sold with or without the BECK intake manifold (same intake I've got listed in another FS thread)
Engine originally cost $13k to build. Was freshened up with new rings, bearings, cam, valve springs and lifters in April of 2014 by True Street in McKinney, Tx. Can provide all receipts.
SOLD for engine minus Beck intake. Intake has been sold!
Built Phoenix Transmissions 4L70e
Billet 300m output shaft
Phoenix says good for 500rwhp in a TBSS. Should handle more in a lighter car.
Freshened in June of 2014.
Phoenix Transmissions #PTGM92/245 Stall converter
3500 stall speed
245mm case
Good for up to 900hp!
This is Phoenix's strongest converter for the 4L70e.
I believe this combo costs between $4k and $5k if you bought it new.
SOLD!
Engine and tranny are out of a 2007 TBSS 2wd.
PM, Text, or call for more info
Dan
469-853-4867
Eagle H-Beam Rods
JE Pistons, 11.2cr
LS7 Lifters
Trick-flo pushrods
Truck pan
3500 stall speed
245mm case
SOLD!
Dan
469-853-4867
