Houston,TX Coils, MSD Wires, 26# Injectors, Mass Air Meter
Time to clean out garage and a few LS items must go. I have some Denso LS1/LS6 coils, Stock Bosch 26-28lb injectors, Delphi MAF and some used MSD 8.5 spark plug wires. Items being sold as-is but came out in perfect working order. Wires have about 8k miles and others are unknown. Engine had approx 84k miles so I would just assume the same. 1 set (8) EV1/EV6 spacers. Used for about 30 min before I switched to different injectors. Nothing wrong with them as I ended up going with a different set of injectors. I also have a set of new genuine C6 Corvette splash guards. Was going to use them on a swap car project and never did. Would prefer local sale for now and can meet in Katy, Cypress and Spring areas. Let me know if you have any questions. Pricing for quick sales....I will not hold anything, first come first serve. Check part numbers, but parts were pulled from 01 Camaro/Firebird application and should be applicable to LS1/LS6.
Thanks
Eloy
Injectors - $50 for set only
Coils - $100 for set only
MSD Wires - $40 for set only
MAF - $40
Corvette Splash gaurds $20
EV1/EV6 aluminum spacers - $10 One injector is darker than the others but ran perfectly even after tuning for heads/cam. Has different 3 digit tag but part number is the same.
