Soundstream tra340.2 (2-channel 340w amp)
$100
Works Perfect
Technical Specification
RMS Power Range : 85-170 Watts
Number Of Channels: 2
Maximum Power: 340 Watts
Low Frequency response: 10 Hz
High Frequency Response: 50000 Hz
Built In Crossovers: Yes
Channel Separation: Yes
Features
OUTPUT (WATTS):RMS @ 4 Ohms: 85x2
RMS @ 2 Ohms: 170x2
RMS Bridged @ 4 Ohms: 340 X 1
T.H.D.: < 0.02%
Frequency Response (Hz): 10 - 50k
SIGNAL TO NOISE RATIO: >115dB
DAMPING FACTOR: >500
INPUT SENSITIVITY: 0.15 - 12.0V
CROSOVER SLOPE: 12dB
CROSSOVER FREQUENCY (HZ): 50 - 5k
DIMENSIONS (INCHES): 10.75x2.6x16
Variable hi pass, band pass, low pass
Variable 18dB bass boost
Double sided glass epoxy SMT circuit board
PWM mosfet power supply
Tri-guard amplifier protection
SMT cooling fan built in
Tri-mode capable
Line output
Works Perfect
Features
RMS @ 2 Ohms: 170x2
T.H.D.: < 0.02%
Tri-mode capable
Line output
