The Start of the Razor S10 build
here is my ls1 vette block I picked for $250 with less than 70k on it
here are my 241 cast heads soon to be ported to flow 310 and have the prc dual valve spring kit new seals yella terra rockers all to accomadate the ms4 camshaft.
here is my dirty intake which im not sure im going to use
radiator setup
This I dont have yet but will be purchasing soon the ladder bar setup i will be using
This is another future part
OR
here is the truck itself
future parts list
ls7 lifters
rollmaster double roller timing chain kit
ms4 camshaft
prd valvetrain kit/patriot gold spring kit
moser 12 bolt
cage
ladder bar install
nitrous 150shot
weiand street warrior intake
fuel cell
arp main
arp head bolts
eagle rods/compstar
wiseco pistons/mahle pistons/JE pistons
long tubes
melling oil pump/ls6 ported oil pump
titanium/ss valves
Well I have alot more but I got a little one who's b-day is coming up but I will be back on track add any comment or questions that you have.
Race truck for sure.
What radiator are you running? I hadn't seen that one before.
I assume you are mounting it all the way in the core support? Will it hang out the back, or sit flush?
Heres a picture of my old backhalfed s10 and my 69 Nova I still have.
S-10s came with a 4ft (only on the 4wd 4dr trucks), 6ft short bed (what this and most are), and a long bed (7ft?).
I really want to build a 2dr blazer, but the shortness of it is what worries me... I like open spaces... and WOT. I just don't see a blazer handling as well as my p/u at 150+.
I think you'd have to have some SERIOUS power to need the excab wheel base stability over a reg. cab. Then again, it sounds like you are building the rearend for it. Personally, I'm just going with a monoleaf, caltracs, and an 8.5in rear.
I used to rock an S-10 too....
BTW, looks like you have the hop-shock also... you got all the goodies
