Tach not working
I have a 99 Camaro and I had the 5.7 short block swapped to a 6.0 and now the tach is not working. Anyone know what it could be?
When I turn the key on it moves with the speed odometer but when The car starts it just sits on 0...
Do you have EFILive or HPTuners? You need to find out if you are getting any signal first - If not, check those connections and devices.
Have you checked the fuse box?
where would the connections be at? I new to messing with LS1's
I will look a this also.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
The crank sensor is behind the starter and requires that the starter is dropped and removed.
You will be able to check the cam and crank sensor with EFILive if you can find someone locally that can come help.
The car does need to be re-tuned because it does have and idoling issue, the motor rev's up when you put it in and out of gear and sometimes when I go to start it, it will backfire a little through the exhaust. All I do is turn off the key and turn then motor over again and it will fire right up. It is a H/C/I car
