Pulling motor out, need advice.
Old Nov 28, 2008 | 08:28 PM
6']['9's Avatar
Default Pulling motor out, need advice.
Ill be pulling the motor out of my 00 camaro tomorrow to paint the engine bay. Currently the trans is out cause im changing the clutch out. I have the book on the ls1 and ls6 motors which gives a little info on removing the motor. However is there anything i need to keep an eye out for while doing this. id appreciate it.
thanks
jay
Old Nov 29, 2008 | 12:06 AM
98Aggie's Avatar
Moderator
pullin out the top or bottom? Have AC?
Call me tomorrow afternoon and i can walk you throigh it.
Kurt
Old Nov 29, 2008 | 12:11 AM
ex-SS-ve's Avatar
i would drop it from the bottom. that way you can get a lil more involved with all the small details before you shoot fresh paint.
Old Nov 29, 2008 | 08:17 AM
6']['9's Avatar
its going to be through the bottom, and yes it has ac. ill send ya a PM so i can get your #
Old Nov 29, 2008 | 08:33 AM
1QWK408's Avatar
Its easier to take it out through the top just take the heads off and it comes right out i have don it plenty of times if you need any help dont hesitate to ask
Old Nov 29, 2008 | 08:42 AM
Deerhunter-Z28's Avatar
Uhh, it's much easier to drop it from the bottom especially if you have access to a lift.
Old Nov 29, 2008 | 12:45 PM
6']['9's Avatar
do i need to remove the power steering pump or can i remove the engine with it?
Old Nov 29, 2008 | 01:00 PM
Everything can stay if you're dropping it from the bottom.
Old Nov 29, 2008 | 01:02 PM
will69camaro's Avatar
Sex On Wheels
Dont even need to take the heads off to pull from top. With a lift or the means to take it from the bottom it would definitely be easier. I've pulled it twice from the top however with no issues, just take manifold off.
You can drop it with the power steering attached but need to remove the pump to take motor off K-member or you'll have to disconnect the lines. Pulling the pump can be a pain...Just takes some time.
William
Old Nov 29, 2008 | 01:23 PM
6']['9's Avatar
im only removing the motor to clean & paint the engine bay since ill be repainting the car. While the motor is out ill do a cam swap & an LS6 intake. thanks
Old Nov 29, 2008 | 06:54 PM
SSAUTOCHROME's Avatar
Don't forget to pull the cam sensor connection from the back of the intake before removal.
Old Nov 29, 2008 | 10:17 PM
JMBLOWNWS6's Avatar
Yawn
Old Nov 30, 2008 | 05:46 PM
blake culp's Avatar
Anyone have a link on how to pull the motor from the bottom using a lift?
Old Nov 30, 2008 | 05:55 PM
6']['9's Avatar
i got it out. Took 3 hours but i got it done next weekend im going to start working on it. thanks for the help
