Tune in San Antonio or near by
Lethal Performance. Murrillos if I'm not mistaken mainly work on Fords and they're good. Lethal ,non-sponsor, do awesome work. Shawn is a great tuner and one of their other techs does an awesome 3 in. x-pipe. Henderson is in New Braunfels. I also heard they do good work from a source or two.
CORRECTION
Murillo is an F-body guy too. He proved it when it was said he couldn't beat the local F-body shops since he was Mr. Ford. He beat Lethal Performance back in day at SAR during a well versed grudge race using their shop Vettes. Murillo came out on top using a G5x4 cam, AFR 205's, and some giggle juice in a stock bottom end LS6. As far as tuning these shops are both more than a contender!
Vid of the fabled vehicle with basic specs can be seen here:
https://ls1tech.com/forums/drag-raci...ottom-end.html
AND
Corey Henderson used to work for Lethal Performance. Drama seperation, now he's their competitor.
Nelson Performance is owned by Allen Nelson who is basically the "truck tuning god" and owner of LS1trucks.com. He does ALOT of turbo trucks!
In the end all good!
Is this the guy that beat the Lethal vette by a 1/10th of a second once? The only reason I said Murillo's was a Ford shop was because I went into their shop this year to buy a part I needed for my throttle body and they said they mainly did Fords. They did fabricate my needed part. Nelson P is awesome on truck tuning. The best actually. All of them are really good shops.
Wrong
Murillo and I NEVER got to race , but his car did haul ***. I was having a lot of clutch issues went thru 4 of them. When we finally got a good clutch then Murillo had to give the car back because it was not his. Our car was running consistant 9.70s at 149 to 152 with the best of 9.59. Not trying to be a dick just trying to give the facts.
CORRECTION
AND
CORRECTION
AND
CORRECTION
AND
Good luck with your project.
Correct , Lethal is now in the shop that Henderson (DynoTex) use to be in and use that dyno thats in the building for tuning . Shawn use to work with Cory and stayed on with Lethal when they took over the shop .
