Clear tailights
Old Dec 22, 2008 | 05:48 PM
WS7_FORMULA's Avatar
Exclamation Clear tailights
Legal or illegal?
Old Dec 22, 2008 | 06:11 PM
rice eater 2's Avatar
legal my couson has some on his car
Old Dec 22, 2008 | 06:14 PM
BizZzatch350's Avatar
Moderator
The older IS300s had them like that from the factory, long as it lights up red I cant see what the issue would be
Old Dec 22, 2008 | 06:35 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Legal and crappy looking.
Old Dec 22, 2008 | 06:40 PM
Sarge_13's Avatar
As long as it lights up red its legal.
Old Dec 22, 2008 | 09:03 PM
Greed4Speed's Avatar
Legal....just like an erector set spoiler.
Old Dec 22, 2008 | 09:06 PM
newton's Avatar
Uhhh, altezzas? Legal on the street, illegal on LS1Tech.
Old Dec 22, 2008 | 10:24 PM
jsteele90's Avatar
pure rice
Old Dec 22, 2008 | 11:17 PM
TRANSdAMn 2k's Avatar
Curveball TECH
x 2 lol
Old Dec 22, 2008 | 11:26 PM
slayer_taunu's Avatar
+1
Old Dec 23, 2008 | 01:54 AM
Believe it or not, but in daylight the lights look amazing. But when night comes around and the lights are on, the red is not so full. It lacks the lenses.....................idk no wat to do. I just dont want to get stopped by pigs.
Old Dec 23, 2008 | 03:16 AM
ThunderZ28's Avatar
Red Bulbs????
Old Dec 23, 2008 | 10:08 AM
avengedws6's Avatar
there legal as long as there is a red reflector that can be seen if light hits it. My friend took his out like you did in his 97, he put em back in 2 weeks later.
Old Dec 23, 2008 | 10:17 AM
SSwt00SS's Avatar
how did you do that?
Old Dec 23, 2008 | 10:29 AM
HERE YOU GO MAN. GOT IT OFF A SITE!
Note: For this walk through, the tail light being used has already been taken apart. The pictures are mainly to help provide you with a visual perspective to go along with. The tail light being used is from a 93-97 Formula/Trans Am, but the process is virtually the same for all 93-02 tail lights.
If you look closely, you'll see where the lens is attached to the housing with RTV silicone. You'll need a basic flat-head screwdriver to separate the lens from the housing. Now, before you start anything, you'll need to know that there are a few techniques of loosening the silicone enough to pry off the lens. Some people use a blow dryer/heat gun, others stick the whole tail light in the oven for about 10 minutes (like the Camaro headlight mod) at around 300* degrees. The tail light wouldn't fit in my oven, so that was no option. Plus, that just didn't seem too bright of an idea. So what I did was simple.. I did nothing. I just went at it. Not the easiet way of doing it, but it worked just fine for me. Might be a little easier for you if you use a hairdryer or heat gun to work the silicone loose.
Now you're ready to start. You'll want to begin on the reverse light end of the tail light, since that's the easiest place to start prying apart.
http://www.blindeyed.com/carpage/gui...erior01-01.jpg
Now wedge the flathead at the inner edge, and start working the screwdriver back and fourth. Don't pry too hard, you don't want to crack the lens and/or the housing. Be gentle, and be patient, and you will see the lens start to lift off some.
http://www.blindeyed.com/carpage/gui...erior01-02.jpg
http://www.blindeyed.com/carpage/gui...erior01-03.jpg
http://www.blindeyed.com/carpage/gui...erior01-04.jpg
Once you have that end of the light loosened up, you'll want to work your way around the light assembly. Pulling and prying wherever needed. Once I had the end loosened up, all I pretty much had to do was start prying the two apart with my hands and the rest popped right off. Not saying it will be as easy for you or anyone else, so please be careful and cautious when doing this. Once you have got the two pieces apart, you'll need to peel off all the silicone that was holding the 2 pieces together. After you've done that, you'll be left with this:
http://www.blindeyed.com/carpage/gui...erior01-05.jpg
There will be tiny little metal tabs holding the plastic lenses down, as you may have noticed while peeling off the silicone. Pry those off with the flat-head, and remove them. It's not necessary to save them for reinstallation.
From this point, all you have to do is apply a new bead of silicone around the edges, and put the lens back on. Make sure you apply pressure to the lid as the silicone is drying. You don't want to end up with any moisture leaks. You can find this silicone at any major auto parts store. It will be labeled as "RTV Silicone Gasket Maker," and comes in an aluminum squeeze tube.
Continued: Making Your lights clear (for 93-97 grid lights only)
Continuing from the above disassembly steps.. To make your own clear lights, all you have to do is remove the red and clear (optional) lenses.
http://www.blindeyed.com/carpage/gui...erior01-06.jpg
http://www.blindeyed.com/carpage/gui...erior01-07.jpg
Now just apply a new bead of silicone around the edges, and put the lens back on. Make sure you apply pressure to the lid as the silicone is drying. You don't want to end up with any moisture leaks.
http://www.blindeyed.com/carpage/gui...erior01-08.jpg
Once you've done that and the silicone is fully dried, you're ready to test it out and see how it looks. Just be sure to have some red bulbs or red led replacement lights on hand before you go off driving.
Old Dec 23, 2008 | 11:31 AM
white man's Avatar
i don't know if it's legal or not but you will get pulled over for those. had something similar years ago on a truck and cops didn't like them even though i had red bulbs.
Old Dec 23, 2008 | 11:37 AM
Old Dec 23, 2008 | 12:40 PM
Nine Ball's Avatar
LS1Tech Co-Founder
The rice patrol will definitely pull you over for that. Wooo woooo!
