View Poll Results: Tahoe or Excursion
Tahoe
75.93%
Excursion
24.07%
Voters: 54. You may not vote on this poll
Excursion or Tahoe
Old Jan 9, 2009 | 07:51 AM
  #41
vette's Avatar
Default Stay away from
Originally Posted by Bad Chad
I think I'm going to go with the Tahoe, I have been looking a little bit. For around 10k I can get a loaded Tahoe with 20-22's, I found a few Excursions around the 10k range and most had an *** load of miles.
The Tahoe does have its advantages as far as easy to maintenance and replace parts/motors if something were to go out.
The Excursion also has its advantages as far as space, towing and Diesel. Parking at the house is not an issue.
We are going to look at a few of each this weekend, unless we see an Excursion we really like then more than likely we will go with the Tahoe
Stay away from Torsion bar suspension if you can. I do not think they are very good. Also watch out for the "SUPER DOOPER" air/hydraulic suspension on the chevy's or the special SHOCK setup" They are crap. Very expensive to repair if wore out!!!! I have one (Tahoe) I know for sure...
Old Jan 9, 2009 | 09:19 AM
  #42
slvrlt1er's Avatar
Diesel Excursion Brotha.....
Old Jan 9, 2009 | 02:16 PM
  #43
OhOneWS6's Avatar
Originally Posted by Texfinn
I'm assuming you are referring to Excursions, not Expeditions...? We've had a 2004 Expedition now for two years and it has been completely rattle and problem free. Has 90K+ miles already. Not too big complaints at the various Ford forums, either.
Excursions are quite different, though.
Nope I meant Expedition. I have 3 friends with them. One 03 the other two are 05 or 06 models. All of them are Eddie Bower editions. All of them are rattle traps. The 03 is the biggest piece of the three. It has constant issues with the door open dinger going off even though the doors are all completely closed. He has had to replace the seat AC module twice and the passenger seat no longer moves. The gear mechanism is stripped. It is a constant issue with that truck. The other two are not much better.
Old Jan 9, 2009 | 03:06 PM
  #44
Hoffs05GTO's Avatar
You need an excursion for the zombie apocalypse!
Old Jan 9, 2009 | 03:11 PM
  #45
Sarge_13's Avatar
Originally Posted by BizZzatch350
Excursion would be cool to mod, chip, exhaust....
A mod just said a 'chip' in reference to a modification?
Old Jan 9, 2009 | 10:13 PM
  #46
70hemicuda's Avatar
ho fo sho
