help me out please....
Old Jan 21, 2009 | 09:39 AM
volcanic2345's Avatar
Default help me out please....
ok i got my 99 ss i was running 7:80s on street tires on motor to the 1/8mile...so i got et streets and a n20 kit... car already has ms3 3600-3800 stall,3:23 gears lid,pace long tubes i was going to spray a 75 shot so i got it tune by the guy who i bought the car from to spray and went home to change the plugs... after i changed the plugs the car started to run like ****, i checked all of them they are all good wires are good,etc. so i take it to the track and the best i can get is a 8:40 what happend lol, and the car acts wierd from a dig... when i take off its like i am taking off in 2nd then a little past 60 ft it will finally down shift i took it back put the tune it had before back in it and found out my 02s are bad but can that be it.. can it be anything else??
this is wierd and also when i am running on the highway full throttle it makes a popping sound so what should i check out?
Old Jan 21, 2009 | 10:51 AM
Trev_SS's Avatar
Change your O2's and see what it shows on the tune. Those can definally make a dif.
Old Jan 21, 2009 | 11:07 AM
just got some new ones today i will put them in when i get off work i hope thats what it is !!
Old Jan 21, 2009 | 11:25 AM
ramairracer's Avatar
check tha alternator to see if its charging i remeber its all bootleg on that car the wires just jammed into the connector at the alternator,
and the gears are 342 since it used to be a 6 speed
and those headers are headman not pacesetter
Old Jan 21, 2009 | 11:43 AM
[QUOTE=ramairracer;10892323]check tha alternator to see if its charging i remeber its all bootleg on that car the wires just jammed into the connector at the alternator,
and those headers are headman not pacesetter[/QUO
alternator is good thanks for other info
Old Jan 21, 2009 | 12:42 PM
Sunset'01Z's Avatar
make sure you got your plug wires on correctly.. and what kind of plugs did you put in?
Old Jan 21, 2009 | 12:53 PM
Originally Posted by sunset'01z
make sure you got your plug wires on correctly.. And what kind of plugs did you put in?
tr6 pluges gap at 40
Old Jan 21, 2009 | 01:04 PM
2 SLOW's Avatar
i think they are gaped too much
Old Jan 21, 2009 | 05:28 PM
adam02gt's Avatar
x2...they come gapped at .35. Thats what I would run.....
Old Jan 22, 2009 | 09:07 AM
Ok now this is pissing me off i put 2 brand new o2s and now it wont idle for ****... When iam at a light it dies out or if iam stop and not moving it will die out it wont stay on for ****... And it is still back fireing when iam full throttle it pops when iam at full throttle i even changed mass air flow and still acting up...what next??? Can it be tuneing ???
Old Jan 22, 2009 | 09:10 AM
Originally Posted by adam02gt
x2...they come gapped at .35. Thats what i would run.....
i had them at 35 at first but took them back out and gap to 40
Old Jan 22, 2009 | 09:57 AM
crAzy95Z28's Avatar
Id maybe go back to your original plugs. If thats not it then it has to be something with the tune...You did say all this stuff started happening atfter tune and spark plug change right?
And to the other poster about plug wires being on wrong. I dont think you can plug LS1 plug wires up wrong. They only go so far and each plug is right over the spark plug. Unlike my LT1, you can get easliy confused
Old Jan 22, 2009 | 10:02 AM
it has the old tune back in it the one where i ran 7.80s on motor with street tires i dont know what it can be
Old Jan 22, 2009 | 10:46 AM
PatriotT/A's Avatar
It sounded like it was running fine last night, but then again I was across the parking lot.
Old Jan 22, 2009 | 11:07 AM
I WISH IT WAS LOL IT SMELLS LIKE STRIGHT GAS WHEN YOU GET BEHIND MY CAR
Old Jan 22, 2009 | 12:09 PM
Bad Chad's Avatar
Check the plugs, you may have cracked one and causing a misfire...
Old Jan 23, 2009 | 08:36 AM
WizeAss's Avatar
does it have cats?
Old Jan 23, 2009 | 09:43 AM
Originally Posted by WizeAss
does it have cats?
no it does not... i thought i fixed it i found a blown fuse then it was not dieing out when i started it but when i drove it it started to act up again but iam going to a well known shop today maybe they can take a look at it
Old Jan 23, 2009 | 09:52 AM
98silvertacrbn's Avatar
x2 i have had the same problem
Old Jan 23, 2009 | 11:22 AM
Dirty 30's Avatar
Maybe its just that slow. :p
