ABS Inop Light
Old Mar 17, 2009 | 11:07 AM
Nemo02Z's Avatar
Default ABS Inop Light
Can someone point me in the right direction? I have recently noticed my ABS INOP light coming on and staying on even after I reset the system. 1. how can I trouble shoot it. 2. Is it the abs sensors? 3. Is it the abs module. 4.Is there a write up on it. I appreciate any help on this
Old Mar 17, 2009 | 11:26 AM
lets_fly's Avatar
i need help with the same shiyt!
Old Mar 17, 2009 | 11:44 AM
FormulaZR's Avatar
Not sure if this helps....but when my 94 had that light on it was because of the brake light being burnt out in the spoiler. My cruise control quit working too....but when I put a new bulb in the brake light the ABS Inop light went off and the cruise worked again....
Old Mar 17, 2009 | 11:58 AM
Nemo02Z's Avatar
unwilling but I checked this theory before, all brake lights are working.
Old Mar 17, 2009 | 01:19 PM
bjamick's Avatar
Check your grounds, mostly the 3 on the back of the drivers side head. I've heard they can cause this light to come on.
Mine just did the same thing and I found a ground loose. Just dont know if it fixed it yet though.
Old Mar 17, 2009 | 04:43 PM
GreatWhiteZ28's Avatar
ABS sensors up front could possibly be dirty, which is the most common problem...just jack the front wheels up, take them off, and turn the wheel to full lock to one side, spray some WD-40 in the back side of the hub and repeat for the other side...when Mine came on it was a combo of the 3rd brake like being out, and the sensors upr front being hella dirty...
Old Mar 17, 2009 | 05:04 PM
Charlie Hustle's Avatar
Believe it or not, I had this light and the "BRAKE" light on for about 6 months. Turns out it was a 10 cent fuse that was blown. I replaced the brake fuse, and both lights turned right off and never came on after that.
Old Mar 17, 2009 | 06:46 PM
mariojmoe's Avatar
Is your car a 3 or 4 channel syster meaning traction control or no traction control? Depending on which one it is Try changing your wheel speed sensors. You can buy the whole wheel hub assembly from o'riely's for about 85 bux +/-. On my previous Z mine had a few abs issues and after changing all three sensors one on the top of the rear pumpkin on a non tcs car, and changing my abs module this cured it. You might want to bleed the **** out of your master too. pm me for any other ?'s related.
Old Mar 17, 2009 | 07:05 PM
Sarge_13's Avatar
Check brake fluid level? Happened before in my friends Camry. Went away after he added some brake fluid
Old Mar 17, 2009 | 07:53 PM
Nemo02Z's Avatar
I am gonna try all those right now.
Old Mar 17, 2009 | 10:18 PM
Blackfly's Avatar
I had this same problem.
I had to replace the EBCM (Electronic Brake Control Module). Brand-New, they go for around 999.99 (GM Parts Direct)
I found a place in Florida that rebuilds them for half the price.
Or you could grab one from a junkyard for $125.
I grabbed one from a junkyard and installed it. The stealership said I was going to have to "flash" it to clear the memory. After I installed the part I drove about 2 miles and the lights just turned off...no issue since.
I think what caused the issue in the first place was when I had to bring my car to an abrupt stop. After that the SS's ABS light would come on "every now and then" until it just stayed on.
Now. Everything works fine.
Old Mar 17, 2009 | 11:28 PM
whitehooptie's Avatar
If anyone is around plano garland or greenville, send me a PM. I have a scantool that reads all that ****. I wouldn't charge you anything, but you'd have to drive to me.
Old Jun 23, 2009 | 06:59 AM
vintageagain's Avatar
Default Reviving the Thread...
Blackfly: when you replaced the EBCM did you replace the valve assembly that bolts to it? In my manual it says to use a new spring between the two, where did you get the new spring or did you use the old one?
Old Jun 23, 2009 | 08:01 AM
Blackfly's Avatar
I just used the old one.
Actually, I had a the guy who built my engine install it. He just swapped them out.
To this date, No ABS lights at all.
Old Jul 29, 2010 | 05:57 PM
davydman's Avatar
What scan tool do you use? That is cool that we can look out for each other and help car guys out
Old Jul 29, 2010 | 06:45 PM
I have an OTC. Goes to 2001, but 02 will work under 01. Wish I had a Tech 2..... Didn't want to spend that kind of money though.
Old Jul 29, 2010 | 07:08 PM
Slash8915's Avatar
It could be several things. When mine had that issue, it was because my headers melted my abs sensor wires.
