Need Help Car throwing multiple codes. . .
Old Apr 2, 2009 | 10:47 AM
SSnemesis's Avatar
Default Need Help Car throwing multiple codes. . .
Car has SES light on and isnt running as usual. I had it checked out at AutoZone and its throwing 6 codes. P0410, P0430, P0137, P0131, P0101, & P1415. If anyone can help me identify these I would appreciate it. Even better is if I can be told how to go about fixing the problem. Thanks.
Old Apr 2, 2009 | 11:18 AM
ramairracer's Avatar
looks like the first and last is for air system, next one the cats is bad if it still has them, and the 137 and 131 are for oxygen sensors, and the po1o1 for the maf,
.. but when a converters bad ad stopped up it will set misfire codes and maf and oxygen sensor codes due to it not runing as it should,
looks like thats what it is , and the air system is useless anyway
Old Apr 2, 2009 | 11:57 AM
SSnemesis's Avatar
Kinda what I figured a clogged cat. I was planning on headers anyway so I'll prob just hack them off this weekend. Thanks for the feed back I appreciate it. Any idea on how to remove the air system seem like alot of dudes on here remove them anyway.
Old Apr 3, 2009 | 01:48 AM
avengedws6's Avatar
Did someone say AIR delete?
https://ls1tech.com/forums/generatio...oval-pics.html
There ya go bro.
Old Apr 3, 2009 | 07:55 AM
twitchtwice's Avatar
i didnt use i write up, i just started unbolting ****. lol.
i did both !egr and !air in about an hour
Old Apr 25, 2009 | 03:56 PM
coatez's Avatar
Default Cat
I own a 01 SS and rec'd a notice from Chevy.
Note: "This letter is intended to make you aware that some 2001 model year Chevrolet Camaro vehicles equipped with a 5.7L V8 engine may have a failure of the left or right catalytic converter. This is not a recall."
It goes go to say "If this condition occurs on your 2001 Chevrolet Camaro within 10 years of the date your vehicle was put into service or 120,000 miles, whichever occurs first, the condition will be repaired for you at no charge."
Something to think about..,
