A new touch to the DSOM C6.
I ended up painting them a flat black, but it didn't really do it for me. It had a masking effect on the polished tips, plus it gave it a dirty look.
So I decided to take the mufflers completely off, strip the black paint and polished the face of the muffler. I can't believe how well stainless steel polishes out. It's almost like chrome. I used some 320 grit sand paper and wet-sanded the surface for a slightly smoother finish since they were already pretty smooth. Then bought some polishing compound specifically made for stainless steel and went to town. It actually wasn't much work at all.
One thing I will point out, RPMs are your friend. I started out using an electric drill, then to a die grinder, and lastly ended up using a air cut-off tool, removing the guard and wheel, and installed the buffing wheel on it. It's rated for 20k rpms. I had the compressor at 90 psi. Seemed to work much better than the other 2 tools I used.
Anyhow, let me know what you think now. I think it gave it a nice touch only costing me a few bucks and a little of my time.
By the way, what you see in the right muffler is the reflection of the crack in the concrete. Oh...I mowed the yard after taking those pics.
Yeah...you should see the back yard. Even greener. It's always greener on the other side, don't you know that?
But seriously, the front doesn't compare to the back. Trending Topics
BTW, nice ride!!!
Rotors/calipers will remain the same. I have no use for bigger brakes and would only serve as an appearance mod.
Thanks for the compliments.
