Cruise Control question. . .
Under my clutch pedal it is a white plastic piece that is threaded. There are 2 under there, I think. Can't remember for sure. There will also be one directly under the brake pedal. They are supposed to disengage the cruise control when either the brake or clutch is pushed in. My cruise doesn't work either and when I first began trying to diagnose the issue, I had found a picture on the internet and attempted to mess with mine, but to no avail. Hope that helped for locating it.
LS1TECH & Trucks Sponsor
It's related to your ABS and trac lights being on, not the module. You need to investigate those systems first. Figure out why those lights are on, the cruise will never work until you work those out
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3451_2.gif)
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
They are for the original poster
__________________
Cruise control module is what the cable hooks up to and should be next to the a.i.r. pump in the lower left fender next to the L. fog lamp. I don't think your lights being on have anything to do with this because you said they have been on for 2 years. They could but if the cruise worked before it's hard to say with out seeing what the codes are.
It doesn't have to be wheel speed sensors, it could also be because or brake lights etc like others have mentioned, anything disabling the ABD/Trac systems and turning those lights on can and will disable the CC with them, as the system deems it unsafe to use CC without Traction Control ability (due to the above mentioned situation of using CC in the rain and the rear end losing traction)
__________________
Listen, cruise works in conjunction with wheel speed sensors (obviously), and anytime there is a problem with that system or any of the sensors the cruise can not work. Period. That's the way it is. He can start troubleshooting the CC module all he wants and ignore my advice, but it will not work again until he gets the issue causing those lights to come on working. Could there be another issue like the switch on the pedal or something with the module? Sure, but you can't troubleshoot all of that until you make it where the system can active anyways. It's related to the reason that if you have cruise on in the rain and the back wheels spin a little it shuts off the cruise, different speeds between the front and rear wheels. If it thinks there is a different speed between the front and rear or if any of the wheel speed sensors aren't working, TCS and ABS lights come on and cruise can not be enabled all because it doesn't know wheel speeds. Those lights are on because it can't currently verify wheel speeds, and without that ability the cruise control will not work.
#35
1 Post
6][9 called it. It was the little button clip had broken for the clutch pedal. Took a giant staple and used it to hold the clip in place and then duct tape to hold staple
Cruise works fine now. For Alls info, cruise control works INDEPENDENT of brakes and ABS. My ABS Inop, Brake/ TCS lights were ALL in all day long.
Thank you if you replied at all for my thread here.
Enig... glad to see you're fixed too.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
