Got a little problem.
Old May 20, 2009 | 05:58 PM
stevensLS1's Avatar
Default Got a little problem.
http://www.performancetrucks.net/for...d.php?t=441434
Thanks guys.
Old May 20, 2009 | 06:43 PM
Midnightnova's Avatar
Hey he drove it with the ebrake on right??
Old May 20, 2009 | 11:55 PM
02CamaroSSLE's Avatar
maybe the ebrake is still ingaged just a little bit... i have an 02 and the cable that connects the pedal to the actual cable down under the truck snapped a couple of years back, but i mean you would be able to tell if it was that... do you smell burning brakes?
Old May 21, 2009 | 10:47 AM
stevensLS1's Avatar
I dont smell the brakes burning at all. Im thinking the line is just snagged up somewhere like you said.
No he didnt drive with the parking brake on.
Old May 21, 2009 | 02:39 PM
98silvertacrbn's Avatar
are you sure it's the ebake and not a broken sensors or a unpluged one for the abs? it's the 08 right? maybe they bumped something or f$$ked something up
Old May 21, 2009 | 04:54 PM
stevensLS1's Avatar
Well the ABS light is on but thats because my front passenger sensor got messed up. The Ebrake light is on now im not sure if its a sensor. Im just going to take it to the dealer i use to work at and see whats up.
Old May 21, 2009 | 04:55 PM
I think the sensor is on the e brake it self. Some one correct me if I am wrong.
Old May 21, 2009 | 05:25 PM
it is but i just thought it could be messing with it idk you could try and loop the sensor for the e brake and see if it goes away
Old May 22, 2009 | 07:03 AM
98FreakZ's Avatar
That light also comes on when there is low brake fluid detected. It has nothing to do with a line moving or something like that. I would start by checking the fluid and sensor there along with the ABS sensors
Old May 22, 2009 | 03:10 PM
stevensLS1's Avatar
Went to the dealership and its the front ABS sensor setting it off. All will be solved soon. Thanks for the help!!
Old May 22, 2009 | 04:38 PM
98FreakZ's Avatar
glad to help
