diesel vs gas
A diesel engine does last longer. Unfortunately, when used in non-commercial applications, they are saddled with so many EPA restrictive devices, like cats, EGR, etc. These add-ons are what's problematic.
And the engine is still surrounded with a body and electronics derived from it's gasoline brother.
Maintenance is outrageous on a diesel. $150 oil changes are not uncommon and they happen just as often as a gas change. Fuel filters run $60 and are required every 15K or so to keep the fuel system in good shape.
And they are freaking heavy. My 07 4x4 deisel 3/4 ton crew cab short box weighs almost 8000lbs! Load range E tires are required and it requires decent brakes to stop all that mass.
I honestly wish I had my 02 8.1 HD 2WD GMC back. It got the same mileage towing and has 1/4 the maintenance costs.
Diesel is fine but just doesn't make sence for many people who buy them anyway because they are considered cool or are easy to make more power through programming. But then since it's all torque you spend a ton to make the truck hold it.
Vernon
However, diesel trucks do have a much better resale value.
All that new emissions **** accidentaly fell off my truck a couple months ago. Must have hit a pothole or something.
Vernon
My HD had a 21 gallon tank and my deisel has a 28. And because of the way it's vented, you can squeeze an additional 3 or 4 gallons in it.
So 21 gallons at 11 mpg is 231 miles and 30 gallons at 13mpg is 390 miles.
And I call B*LLSH*T on 20 mpg @80 with a 10K load.
20 ain't gonna happen unless travelling down a 10% grade ...
a side note, on a road trip, pulling 6000lbs, 841 miles, I averaged 18.6 mpg, doing 70 mph the whole way......I consumed 51.5 gallons of fuel....
another side note: I love blowing the doors off a mustang or a honda in a 7000lb truck
