xbox live help
Old Sep 27, 2009 | 01:52 PM
camAro242's Avatar
Default xbox live help
Im trying to get my xbox live connected and each time i try it keeps saying Your DNS server can't resolve Xbox LIVE server names i copy the exact same dns's #s from my computer to the xbox but once i copy them my xbox still says the same thing. Any suggestions?
Old Sep 27, 2009 | 02:53 PM
burritoboy9984's Avatar
just use dhcp and automatically detect settings... it should work..
-Erik
Old Sep 27, 2009 | 03:12 PM
camAro242's Avatar
-Erik
iv tried the auto settings and it still doesnt work, im trying use the dhcp
Old Sep 27, 2009 | 03:25 PM
what kind of internet do you have? and how is it connected? modem... router... etc
-Erik
Old Sep 27, 2009 | 03:27 PM
twitchtwice's Avatar
yeah you cant use the dns off your computer because each device will use its own on a network. and yes same question as above. how do you have it setup?
Old Sep 27, 2009 | 03:28 PM
camAro242's Avatar
my set is a modem to router then either net cords from the router to the xbox/computers ect
Old Sep 27, 2009 | 03:51 PM
westtexasbuff's Avatar
It shouldn't even ask you for anything if you're wired.
Have you tried doing the XBL test?
What does the error say when you run it?
Old Sep 27, 2009 | 03:54 PM
Pitbull329's Avatar
My xbox wouldnt connect when I first set it up with the router. Go to your router settings page.
If you have any issues connecting on XBL make sure:
You have your xbox getting a static IP
You have the proper ports forwarded for the xbox's static address, specifically:
* TCP 80
* UDP 88
* UDP 3074
* TCP 3074
* UDP 53
* TCP 53
Old Sep 27, 2009 | 04:14 PM
camAro242's Avatar
yes and, Your DNS server can't resolve Xbox LIVE server names
* TCP 80
* UDP 88
* UDP 3074
* TCP 3074
* UDP 53
* TCP 53
i really dont know about that, i dont have a clue what is tcp 80 and all that
Old Sep 27, 2009 | 04:16 PM
i would unplug your router and your modem for about 30 seconds. durning this time your xbox should be off. plug them both back in and wait until both are initialized then once they are turn your xbox back on and it should automatically log in since its lan.
Old Sep 27, 2009 | 04:17 PM
camAro242's Avatar
this did not work, i have everything on automatic
Old Sep 27, 2009 | 05:47 PM
ZONES89RS's Avatar
In-Zane Moderator
Dial up doesnt work for Xbox live.
LOL, sorry.
Your PC works fine right?
Old Sep 27, 2009 | 05:56 PM
Dewey's Avatar
he didn't say anything about dial up. OP how long have you owned that router and what brand/model is it
Old Sep 27, 2009 | 06:28 PM
Try connecting that same ethernet port to your PC and see if internet works, if it doesn't, then you know it's something with your setup.
If it does, then I would call your ISP, as sometimes they block XBL ports.
Old Sep 27, 2009 | 07:27 PM
Pitbull329's Avatar
noo nooo you guys.
He needs to have his ports forwarded to those settings I gave him.
Turning off everything and turning it back on wont do a thing. His ISP has nothing to do with the blockage of the XBL ports. Its his router itself. It might be UPnP (universal plug n play) but that dont mean crap when it comes to XBL. Im 95% sure that if he forwards his ports,itll work. The other 5%... could be anything lol.
Read the long post in this link
http://forums.linksysbycisco.com/lin...read.id=138079
Yes, your router might no be linksys. But either way, that guides you through the steps on what you need to do. Still have trouble, let me know... i'll try to help ya out. It frustrated me when I couldnt figure it out. Following those steps, it finally worked and works flawlessly.
Old Sep 27, 2009 | 07:42 PM
camAro242's Avatar
noo nooo you guys.
thanks for the link, i have a linksys EtherFast® Cable/DSL VPN Router with 4 Port 10/100 Switch
and no i do not have dial up lol
Old Sep 27, 2009 | 08:16 PM
camAro242's Avatar
i got a problem i cant access 192.168.1.1 it keeps saying it times out
Old Sep 27, 2009 | 08:30 PM
ZONES89RS's Avatar
In-Zane Moderator
Was a joke.
Old Sep 27, 2009 | 10:16 PM
try connecting it directly from the modem to the xbox and skip the router/switch you have setup. also, if you are plugging a switch in directly from the modem that will not work.
Old Sep 27, 2009 | 10:18 PM
817Borla's Avatar
ok hope this helps first you have to set up a static ip address on your xbox follow instructions on link http://portforward.com/networking/staticip-xbox360.htm
now you have to forward the ports click on the link it has the instructions for your router http://portforward.com/english/route...x_Live_360.htm
it might be a little confusing if you have any question just msg me or reply on here.
