Going crazy, need HELP!!!
Have you tried turning off the car, but leaving the key in it and then restarting? If it restarted like that, I'd say it's the alarm.
Also, make sure the cable that goes to the starter is tight.... mine wiggled loose and had to tighten it not too long ago.
The next time it won't start, try giving the starter a coulple of taps with a small hammer or something heavy. If it starts immediately afterwards, it is definetly a bad starter.
Thats exactly what i was thinking.
It was the ignition switch. For some reason, it wouldnt completely shut off when I would turn the car off and burned because it had burn marks on it. The Viper alarm had taken a crap as well (which I was told could have been due to the ignition never completely shutting of (whatever). New ignition switch (which is a major bitch to take off), factory alarm, and a new battery (just in case) and its back to normal. I will replace the starter in the next few months just as a precaution too. Thanks for all the recommendations/diagnosis.
