edge stall/converter
so i guess i can use it. ok the thing is i already have one but i paid 300 for it. its 2800-3000 stall/converter. i had originaly bought it for my thirdgen but never slapped it on, but i now have an 01 TA, and before i sell it i wanted to check and see if i could use it.
The 9.5" Street Edge weighs apx. 26 lbs. (15-17lbs lighter than average 12" torque converter), transmits less shock to the driveline, therefore longer drivetrain life, quicker 60 ft & faster quarter mile times. Stall math & STR are set for your specifications & configured using only "True Stall". No cutting, bending, No excess heat! Flanged, Chrome-moly drive hub, furnace brazed pump & turbine. All wear surfaces are fitted for enclosed bearings for less drag & increased longevity. Input splines are chrome moly heat treated for increased strength. Screw-on pilot allows you to add a mid-plate later, without changing torque converters
reason why i ask because it says 700r4/4L60E
