Computer smart people please help????
Old Dec 17, 2009 | 09:09 AM
jebuzws6's Avatar
Question Computer smart people please help????
Just wondering if I can fix my computer with buying a wireless router? I have DSL and have the modem connected straight to the computer with the ethernet cable. But about like a month ago the ethernet connection on the back of the computer is not working (IMO), it has a green light that would light up when the cable was connected but now it does not even light up or anything. The modem works when I connected to the PS3 and play online but I have no connection when I connect it to the computer. You guys think buying a router would give me internet access again?
Thanks,
Old Dec 17, 2009 | 09:17 AM
twitchtwice's Avatar
no a router wont necessarily help, if your ps3 is working that means that there is something wrong with the desktop. there could be a few things other than the ethernet port going bad. if its blinking that *usually* means its receiving a connection and somewhere within the software on the computer it is not allowing you to use the internet.
i can help you with a series of questions.
do you have any virus protection on the computer?
if you do is it still an active subscription? if not then remove it.
is it norton? remove it either way lol
if you have multiple virus protections remove them until there is only your favorite left
if none of those apply. open up a command prompt and type in:
netsh int reset all
hit enter and type this
netsh winsock reset
then hit enter and the second message should say "You must restart your computer....."
restart it and see what happens.
Old Dec 17, 2009 | 10:13 AM
allan808's Avatar
netsh int reset all
netsh winsock reset
if all this dont work,reinstall ur ethernet driver..that should work! look up ur motherboard make and model and go to there website and download the latest driver or drivers for the motherboard..
Old Dec 17, 2009 | 10:28 AM
chon79's Avatar
+1. Try reinstalling drivers
Old Dec 17, 2009 | 10:57 AM
redz_02's Avatar
Any recent changes made?
Start>Settings then right click network connections and select open.
You should have at least one Local Area Connection. Just double click the connection, don't open properties. You should see a Sent/received packets display. Check and make sure the Status is to Connected (don't think it should). Also just by double clicking the Local Area Connection it will automatically enable the device if disabled. Try disabling the connection then re-enabling it. This works with the services and will refresh the application.
Are you using the same cable? Ethernet cables can go bad escpecially when swapped between devices continously.
Personaly if you have two devices that need access I vote to get a router anyways. PS3 supports a G connection so you can find a G class router for around 20-50 bucks, and when you install a supported agent on your PC you will be able to share compatible files to the PS3 such as video and audio files.
Also try this:
1Open the Command Prompt (from the Start button, go to Programs > Accessories > Command Prompt). Or select run in the start menu and type cmd, hit enter.
2In the command prompt window, type ipconfig to see current ip address
3In the command prompt window, type ipconfig /release
4In the command prompt window, type ipconfig /renew
5Exit the Command Prompt by typing exit
This should recontact your providers dhcp server (what gives you an IP).
Still doesn't work, reinstall drivers, that doesn't work time to reimage the CP.
Old Dec 17, 2009 | 11:40 AM
02ws666's Avatar
+500 on just reinstalling the ethernet drivers. specialy considering no light comes on on the board when its plugged in.
Old Dec 17, 2009 | 01:44 PM
jebuzws6's Avatar
alright guys ima try the first suggestion of restarting the system than ill let u know what happens. the only security system that i have is Mcafee. how do u reinstall the driver? is it a complicated process
Old Dec 17, 2009 | 02:17 PM
is the mcafee a current subscription. sometimes when they expire your internet stops working because the software will install itself in the network settings. so if the mcafee is not working, sometimes the internet will stop working.
Old Dec 17, 2009 | 02:46 PM
Camaro Junky's Avatar
If the driver reinstall does not work you can get a USB wireless adapter. Belkin is cheap and works. You will connect your ISP modem to the wireless router you will have to buy.
The wireless adapter is USB so you will not need a RJ-45 connector. Only do this if you are 100% sure the 10/100 Ethernet on the motherboard is toast.
G standard is cheap and works fine.
http://catalog.belkin.com/IWCatProdu...duct_Id=459553
http://catalog.belkin.com/IWCatProdu...duct_Id=179211
Old Dec 17, 2009 | 02:50 PM
allan808's Avatar
installing a driver is as easy as a click! just download it and click the install when done just reboot,should work if the ethernets not toast..if it is a new ethernet card is under $20..
Old Dec 17, 2009 | 02:56 PM
Good call, but I figured with him not having a router he is kinda of exposed to the world. Also if he does get a NIC, we have to make sure he knows what he doing on the install...
Old Dec 17, 2009 | 04:37 PM
redz_02's Avatar
Yup, make sure you are not updating the firmware, you could ruin the board doing this. If you need an new ethernet card I have a crap load laying around. Just need a free pci slot.
Old Dec 17, 2009 | 04:53 PM
02ws666's Avatar
go to the makers website from another source
search model/product
dl the Ethernet driver.
install
access pornhub all you want
Old Dec 17, 2009 | 05:11 PM
redz_02's Avatar
install
You could also use the disk that came with the motherboard/pc. Won't be up to date, but don't think he can access the internet. Then again he did post on ls1tech.
DL it to a thumdrive or burn it to a disk. Should work that way to.
Old Dec 17, 2009 | 11:15 PM
jebuzws6's Avatar
ok guys i tried mostly everything u guys suggested and nothing seemed to give me any results. i keep having nono signal comming from the cpu. i reseted what u guys suggested and tried to enable stuff also took of my Mcafee but still nothing. I have no internet im only able to post cuz of my mobile phone. the only thing i still havent done is reinstall the drive because i dont have the original cd or internet, so what can i do guys. U guys think i should just try the router? thanks... please help cuz this mobile phone internet sucks..lol
Old Dec 17, 2009 | 11:47 PM
02Z28LS1's Avatar
you could try going into the device manager, uninstalling the current drivers for the LAN adapter, then restart the computer and see if it automatically reinstalls the LAN drivers again. if not, you will need to get access on another computer somehow and try downloading the latest LAN drivers from the motherboard manufacturer's website and bring it home on a CD or USB flash drive or something.....if reinstalling it still doesn't work, and the light still does not light up when plugging in the LAN cable, the LAN adapter is likely toast. at that point, it's time to get a new LAN adapter....good news is they're pretty cheap.
Old Dec 17, 2009 | 11:50 PM
whitehooptie's Avatar
Just go buy another PCI enthernet card. They're $20. All you need is a phillips-1/4" screwdriver. Takes 2 minutes. Depending on the os, it'll install drivers automatically.
Old Dec 17, 2009 | 11:51 PM
You know what, if you're around plano bring it to me and I'll fix the damn thing. Just buy the parts. There is a frys across the street from me.
Old Dec 18, 2009 | 12:01 AM
edzsilverss's Avatar
What he said. If the light goes out, fix the bulb lol. That will take care of you. Been doing this **** for years.
Old Dec 18, 2009 | 02:14 AM
No ****. Trying to fix something like that should only be 15 minutes. After that, replace it. I've been in field work like that for 12 years and it is more cost effective to buy a new one.
And on a side note, if you're broke I've got about 10 ethernet cards lying around you can have.
