Clutch Blleding
Old Jan 16, 2010 | 02:41 PM
camAro242's Avatar
Default Clutch Blleding
Can any one tell me where to bleed the Hydralic Clutch on my 1999 Trans Am.
Old Jan 16, 2010 | 03:12 PM
98Roller's Avatar
crawl under your car. find where bell housing meets tranny. about 10 or 11 oclock on the tranny is the bleeder valve.
Old Jan 16, 2010 | 04:48 PM
camAro242's Avatar
Default Missing Bleeder
Any chance it could be missing. I have reached to the top of the tranny and no bleeder valve.
Old Jan 16, 2010 | 04:50 PM
camAro242's Avatar
Anyone know a link to cutting a hole to get at bleed valve?
Old Jan 16, 2010 | 06:03 PM
THE BLACK WIDOW's Avatar
here ya go.....
https://ls1tech.com/forums/manual-tr...-yourself.html
Old Jan 16, 2010 | 10:26 PM
TechCam97's Avatar
Originally Posted by THE BLACK WIDOW
I did this in mine and it has been a time saver! I was busting my knuckles bare trying to do it from under the car.
Old Jan 17, 2010 | 03:45 PM
camAro242's Avatar
So after spending considerable time finding and bleeding the clutch. I have found that the clutch is fine until I start the car then the pedal goes straight to the floor and stays there until i take my and and rapidly pump it back up. Then its good for one shift and back to the floor. Does this mean bad slave? Please help!
Old Jan 17, 2010 | 08:51 PM
JayBee's Avatar
Not sure if you know about the clutch master cylinder on 98-00 f-bodys. But they are trash. Most likely you need a new master cylinder if you havent replaced the stock one. If I was you I would NOT go back to the factory master because you will just have the same problem. Take a look at the "Tick" Clutch Master cylinders. They are a bit pricy but well worth it.
Old Jan 17, 2010 | 09:29 PM
98LS16T56's Avatar
I dont know if this helps at all. But this was my problem
https://ls1tech.com/forums/manual-tr...l#post12667777
Old Jan 18, 2010 | 10:25 PM
gun4hire's Avatar
Not sure if you wound up cutting the hole or not, but if you'd like one of the remote bleeders I have one that has never been used for sale. PM me...
Old Jan 18, 2010 | 11:36 PM
slayer_taunu's Avatar
i installed one of those remote bleeders when i had my clutch swapped out. i advise everyone to do the same... it makes bleeding the clutch 100x easier
Old Jan 19, 2010 | 07:59 AM
SleeperZzZ28's Avatar
just as easy to do drill mod and its free lol. Except i had to cut my poor car but she did loose.00003lbs its win/lose/win
Old Jan 19, 2010 | 08:19 AM
one of the benefits to the remote bleeder, besides not having to cut the car up, is that you can just attach a hose to it (or a mityvac), so it makes clutch bleeding a clean job. plus, there is no opening/closing a bleeder gymnastics act with every pump. it just has a speed bleeder on the end, so you just pump the pedal and keep checking the res.
Old Jan 19, 2010 | 12:19 PM
1c62nv's Avatar
Default try this
http://performanceworks1.com/ls1_clutch_bleeding.htm this is the oldest trick in the bookI am suprised that it hasnt surfaced yet,try it it works
Old Jan 19, 2010 | 01:41 PM
camAro242's Avatar
thanks for all of the help guys, we got my brothers car bled and its the clutch that is causing the problem
