6.0 swap
Old Mar 16, 2010 | 11:03 PM
1Down lsx's Avatar
Default 6.0 swap
Hey well i wanted to know what all is nesesar to do a 6.0 swap on a ls1 is it different wireing harnet different tranny what would you need and is it time consuming thaks,
tony
Old Mar 17, 2010 | 08:04 AM
NastyC6's Avatar
If your 6.0 is a 24x reluctor wheel,everythings the same.just use all your sensors.sometimes the oil sending units different. your harness will work just fine.
Old Mar 17, 2010 | 08:40 AM
the_merv's Avatar
Veteran: Air Force
Just have to drill & tap for the Alternator Mounting Bolt on the outer Ear on the Ironblock. That and check the Crank to make sure it doesn't have the long Flange or a Spacer.
