Oil Pressure Issue?
Old Mar 22, 2010 | 10:35 AM
SSnemesis's Avatar
Originally Posted by Sykokilla
Problem fixed.
I went and got my oil changed. Had them put new Mobil 1 5w 30 and Wix filter.
The pressure actually changes again with throttle and after a 2 hr drive has never seen 20 psi THANK GOD! highway 40-50psi idle 36psi WOT 58psi
I really hope you get everything going good OP. Good luck bro!
Good to hear everything worked out for you man. Now you can keep it and not get into a crappy civic, LOL. I am going to do the same here prob this weekend (just never enougth time). Once I do that I think I'll also do the LS6 oil pump since Im taking things apart anyway. Thanks for the feedback.
Old Mar 23, 2010 | 08:33 PM
Sykokilla's Avatar
No problem! Its whats LS1Texh is here for!
Old Mar 28, 2010 | 11:22 PM
bongva's Avatar
any updates OP?
Old Mar 29, 2010 | 11:04 AM
MATTKO91Z's Avatar
Damn... I'm having the same issue. Hopefully it's just the filter.
Old Mar 29, 2010 | 12:27 PM
cambirdracing's Avatar
Me too. Gonna change the oil and filter this week. Gonna try a Purolator and get rid of the Fram and see what happens.
Old Mar 29, 2010 | 03:03 PM
SSnemesis's Avatar
Originally Posted by bongva
any updates OP?
no updates, sorry. I ment to do it this past weekend but got sick and couldnt do much of anything. Going to buy the parts for it this week.
Old Mar 29, 2010 | 06:56 PM
ragu1585's Avatar
im havin the same oil pressure signs with my car.. starts up at bout 40 then after gettin hot its 24-26ish and sometimes drops a little lower like 20-22 but comes back up to 24-26.. wot throttle up to bout 5k rpms im just barely over 50psi (havnt went over 5k rpms)... usually when im driving say im bout 2000 rpms im sittin bout 35psi.. 2500 rpms im bout 40psi (thats not gettin on it just keepin it bout those rpms)..
ive made an appointment to get my oil pump changed cause i was thinkin that it may have some lil shavings as my cam backed out due to the original shop not using locktite when the cam was installed!! .. car runs flawlessly other then that!! im gonna change my oil to and see what that does for me!
Old Mar 29, 2010 | 07:06 PM
1998LS1SS's Avatar
I have the same issue. At WOT warm, i used to get 60psi now it wont pass 50psi. When the car warms up at idle i the needle tends to be kinda jumpy from 30-35psi. Hit the gas and it moves up to 40psi. I bought a new oil sending unit and melling high volume pump but im going to wait to throw it on when i do a cam swap.
The one concern i have is that if its not my oil pump or sending unit it could be that my motor is leaking on the cylinder walls. I guess i need to research how to do a leak down test. Anybody know how?
Old Mar 30, 2010 | 04:28 PM
blkbird's Avatar
Same problem her a couple years ago and ended up being my cam retainer plate. The little gasket had blown out and the bolts had come loose. Put in a new one and now i have massive oil pressure. Just throwing that out there. I have a post out there with some pics.
Old Mar 30, 2010 | 05:09 PM
1998LS1SS's Avatar
Thanks. I'll look it up.
Old Mar 30, 2010 | 05:28 PM
ZONES89RS's Avatar
In-Zane Moderator
Yea, when i put my cam in i replaced the cam retainer plat with a new one and used loc tite on the bolts, but my pressure has not went below 30 lbs at idle, cruising it is about 35 at 1800+/-, and i have been beating the **** out of it so i am going to have to call it good.
Old Apr 2, 2010 | 04:36 PM
  #32
MATTKO91Z's Avatar
FIXED!
Changed oil and used a Mobil 1 filter. Expensive filter but well worth the peace of mind.
Thanks for all the input guys!
Old Apr 9, 2010 | 01:02 PM
  #33
ragu1585's Avatar
any other updates???
i just changed my oil, went with a lil heavier weight since its what i had layin around, but i bought a mobil 1 filter..
so far my results have went like this..
start up: before bout 40-42psi - now bout 55psi
heated up @ idle: before bout 22-26psi - now 36-42psi
wot: bout 5k rpms only 50-52psi - now ive seen 78-80psi wot prolly bout 5500-6k rpms
im not gonna get too excited now but im goin to see how it does..
ps what oil and oil wt does every1 use
Old Apr 9, 2010 | 01:27 PM
  #34
1_fast_gto's Avatar
have any of the posters with the ideas of changing out their oil pumps and dropping their oil skillets and what not done and actual pressure test. where you install the oil filter adapter and use a manual gauge to read the pressure? just wondering. oh btw, delco filters are reallly good... i mean they do put them on at the factory. just sayin. lol
Old Apr 9, 2010 | 01:49 PM
  #35
ZONES89RS's Avatar
In-Zane Moderator
10w30 for me.
Old Apr 9, 2010 | 04:11 PM
  #36
ragu1585's Avatar
ive always used a thick oil myself.. 15 50 mobil 1 in the last car and i think 15 40 and 20 50 castrol in this car
Old Apr 9, 2010 | 04:34 PM
  #37
TPRDFW's Avatar
i use 15w 50 mobil one with a k&n extended filter on my built motor and it gave me like 15 more psi over my 5w30 and fram filter
Old Apr 9, 2010 | 05:52 PM
  #38
ragu1585's Avatar
my first vette wasnt built motor but heads cam and i ran the 15 50... this new one has a built motor.. tx speed recommended not puttin synthetic in it for like 1k miles or so and so i still run the castrol (ide feel dumb if it was synthetic haha)
where can you get this k&n extended filter you speak of...
Old Apr 12, 2010 | 09:19 AM
  #39
SSnemesis's Avatar
UPDATE:
Before tearing into it I decided to do the simplest thing, change oil filter and oil. Went with mobile 1 filter and oil (special at autozone). So far the car is holding up pretty good. Hasnt seen less than 40 psi at idle and about 60 at WOT. Thanks for everyone's insight.
Old Apr 12, 2010 | 09:24 AM
  #40
ragu1585's Avatar
update on mine.. not good.. not sure whats up but motor will be coming out!!
