A true 2010 SS vs 2011 GT 5.0 article.
I worked up a little for the gear ratio change to 4.11 in both cars to show the acc dif and how much of n advantage the camaro will have from a simple swap.
Here is the mustang
notice a 10.2% change in accl.
Here is the camaro
Notice a 19.1% change in accl.
I know the tire sizes are not right but that wont make a difference on the %. The % will also be the same w/ whatever gear ratio you choose 4.10, 4.11 doesn't matter.
Have I owned Fords? Yes. Have I owned GM's? Yes. ****, I even owned a Dodge at one point
. Point is, I don't suck and brands dick 24/7 and I actually like more than just one brand. If that makes me a "Ford fan/pony boy" then so be it.
You are a idiot. So I am just going to state this once because you obviously haven't read anything that I have wrote. The mustang looks a bit more fun to drive when you are going to a good warranty car.(looks because I haven't had the chance to drive one) If I buy a car I am not planning on leaving it that way and from what it looks like dollar for dollar the camaro will be way cheaper to mod. Gears(get more out of it % wise) and cam(only one). I am done with you since you obviously are way one sided. Take a breath relax and stop taking a negative twist off of what I am saying you are just proving that you ARE in fact a douche.
WTF is your point? A modded LSX beats a bone stock mustang. Wow.
Sure, you can probably go further with a Camaro (LS3 based stroker motor), but that's not too cheap.
The new Mustang is a great choice for your average muscle car enthusiast looking to buy a new car with a $40k price cap.
