This Is For Real...
http://www.world-racing.com/AugustWS2010pr%20.html
Type: 2010 Scion tC
Engine: Descendant 2AZ-FE Factory Scion tC 4 cylinder
Transmission: Weismann Transmissions + Lockers
Suspension: Penske Racing Shocks
Rear End: Winter's Quik-Change
Brakes: Brembo Race
BHP: 1,400+
TQ: 1,000+
Weight: 2205 lbs. w/ 160lb driver + fluids
Stupid is your inability to wrap your mind about what is being done with a car in a class that has allowed him to garner success.
I am sure you thought the 70's in Formula 1 was a gigantic waste of time as well when cars like the Tyrell P-34 were running around the track:
Type: 2010 Scion tC
Brakes: Brembo Race
BHP: 1,400+
TQ: 1,000+
The two main advantages of a front-wheel drivetrain are fuel efficiency and traction. In a front-wheel drive vehicle, the engine and differential are located in the front end. The engine filters all of its power through the differential into the front wheels, which creates a pulling effect. As Popularmechanics.com notes, this type of vehicle has less weight in the back, and is usually smaller, due to most major parts being located under the hood. This produces a more fuel-efficient vehicle.
Since most of a front-wheel drive vehicle's weight is in the front, it will have better traction in poor weather conditions.
Remember, not everyone lives their life a quarter mile at a time. I don't think the article gives the FWD platform the traction advantage when increasing speed, but under poor weather conditions during normal part throttle cruising. You don't have to be accelerating to lose traction, in whch case there is no weight transfer.
Speaking of weight transfer, would the FWD platform have the advantage when braking?
Drive wheels shouldnt dictate braking performance, the balance of the car, brakes, overall weight, bla bla bla, is what matters. Compression braking may play a small part, but then again, I count on the rear dragging a little into turns. Dont think I would like the compression braking coming from the front. Seems like a good way to slide out braking hard and downshifting coming into a turn.
