Opti problems in the rain!!!!!!!!!
How to modify LT1 intake for use with distributor.
The pictures can't be clicked on and made larger, but they are big enough to see what he's talking about. If you don't want to give this a try then you can always either replace your opti with a different unit or get rid of it all together with a Delteq Direct Opti Replacement Unit. It's just under $800, but it takes the opti out of the equation completely.
Thanks man i appriciate it im ordering that bitch now lol im tired of thos opti **** man the worst design ever but win its runing rite its flawless but appriciate all the input guys
*EDIT* - But it's your car man, I don't want to sound like you HAVE to go the Delteq or distributor route. I just want to let you know that there are options out there other than an opti. Depending on how often you drive your car in foul weather, the MSD will probably be just fine. Just know that it's not a 100% cure. You may put one on and then never notice the issue again, or you could put it on and be fine for a year or two and then have a seal fail and experience the same issue when it rains again.
Well **** lol!!!! Ill try the msd man money kinda of tite rite this minute. My wife drives this car more than i do lol. So can i just take old cape of and button and put msd on that distributer. (msd) cap and button is that ok to do
The opti is not that bad to change, I can do one in about 3 hours start to finish if I'm taking my time, but that's also because I've done it quite a few times. In your situation I think you should look at the vacuum and vent lines on the opti. There is a vent on the bottom that will take in moisture, but that moisture is supposed to be sucked out by the vacuum line on the opti that goes into the intake. It has a blue thing on it that I don't know if it's a check valve or a filter. If that line is attached and working then the moisture should be getting pulled out. The best advice I can offer is to carry a can of compressed air with you and when the moisture gets in there just put the straw in the vent hole and blow it all out. That will get you back running for almost free.
