ls1 water pump???
Felpro FTW on this.Just like the old 3800 intake gaskets, felpro is much better than GM.. Last time I went to the dealer to see how everyone was doing(father was forced to retire, heart surgury etc) their was a massive *** pile of LS pumps in the floor, I mean probably 65 of them.
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
Not sure if you saw the OP's other thread but this is a 6.0 in an s10 with heads and cam, so Im sure the cooling system is anything but all original.
could you guys go into more detail as to why the 1 dollar/gasket felpro's are better than the more expensive GM gaskets?
as far as our 4th gens go, why wouldnt GM change back to the paper gasket in 2000 if the metal gasket with the rubber doesnt do the job as well?
it just doesnt add up (make sense) to me.
thanks
thanks
thanks
thanks
Just look at brake pad technology most gm cars will go 120k pulse on pads then look at a ford or dodge by the time they hit 1200k they have had about 3 if not more brake jobs. Why is that? Its not because the technology is not out there...(Its because brake jobs make the company money)
http://www.summitracing.com/parts/NAL-89018052
http://www.summitracing.com/parts/NAL-89018053/
Notice the part number and price difference.
I have thought about going with a higher flow WP also, with the thinking that for some reason #7 runs hotter (FI) and maybe circulating the water a little quicker would help out and keep it a little cooler.
I didn't see one on LMPerformance for an LS1. Anyone know any other suppliers that have them?
#32
I will say this once, circulating water faster is good!
The longer water sits in the radiator the longer it sits in the motor, the faster water moves the cooler it will stay therefore the higher flowing the better.
