Surging in gear!!!!
Old Nov 22, 2010 | 11:17 AM
speedZ28's Avatar
Default Surging in gear!!!!
I have a 96 camaro lt1. I was out driving it the other day after the car warms up after a couple hours of driving her u come to a red light as ur stoping in gear (auto) waiting to turn green the rpm gage is jumping back and fourth from 500 to 1000 wth!!! So i have put new plugs,wires,cape,button, fuel regulator and i took intake off to put new intake gasket on and fixed all the oil leaks bc the oil leak was messing up my opti. Im kinda out of ideas do u guys think it mite need to be tuned bc i dont think it evet has nething would be greatly appriciate ne ideas at all thanks guys
All the stuff that is dun to car
Rr 1.6
Roller cam dont no spect
Roller lifters
Port and polished heads
And intake matches heads
Port and polished fuel rail
And shorty headers
If nething else is dun i dont not wat it would be. If u guys thinks it needs to be tuned and thats why its surging let me no thanks
Old Nov 22, 2010 | 11:19 AM
Mike TexaSS's Avatar
8 Sec Tuner
Your EGR valve might be stuck open. Check the back of the intake.
Old Nov 22, 2010 | 02:39 PM
fasttagurl's Avatar
If you do not figure this out feel free to bring it by the shop so we can thoroughly look everything over & see what's going on.
Old Nov 22, 2010 | 03:23 PM
GreatWhiteZ28's Avatar
This......happened with mine awhile back when I had m LT1....
Old Nov 22, 2010 | 04:32 PM
old93camaro's Avatar
could be your IAC value sticking
Old Nov 22, 2010 | 05:25 PM
speedZ28's Avatar
I just checked my egr its fine now the iac. I dont no much bout that isnt it located on top of tb if so cleaned that win i clean my tb bc it was all black ne other suggestions guys that would be great
Old Nov 22, 2010 | 05:37 PM
if I remember correctly, "cleaning" your IAC won't fix it...if it's bad it's bad....
Old Nov 22, 2010 | 05:54 PM
speedZ28's Avatar
Is there a way u can check it or is that just a throw away and just buy another
Old Nov 22, 2010 | 06:45 PM
redz_02's Avatar
I had the same issue a while back. Ended up being a bad TPS sensor.
Old Nov 22, 2010 | 08:23 PM
transam5.7lt1's Avatar
Check engine light on?
Old Nov 22, 2010 | 09:02 PM
speedZ28's Avatar
No the light is not on every now and then it will come on and it says missfire, vacum or fuel but everything is good or its checking out good
Old Nov 22, 2010 | 09:06 PM
speedZ28's Avatar
Wouldnt a tps senser do it all the time if it was bad!!!!
Old Nov 22, 2010 | 11:21 PM
redz_02's Avatar
It was only noticable at idle.
Old Nov 23, 2010 | 12:02 AM
Jake_the_Snake's Avatar
not really. electrical parts often act up intermittently. my tps did somethin like this before i replaced it. now, it surges a little but it started after i had a stall put in. think its somethin with the tune
Old Nov 23, 2010 | 07:56 AM
speedZ28's Avatar
Is there a way to check the tps
Old Nov 23, 2010 | 01:09 PM
redz_02's Avatar
They are pretty easy to find online. I would also take a look at the front 02's, but you said no code is being given.
Might consider a tune. How many degrees of overlap is your cam built for.
Old Nov 23, 2010 | 05:13 PM
speedZ28's Avatar
Man i have no idea? I dont no nething bout cam it was in car win i bought it.
Old Nov 23, 2010 | 07:10 PM
redz_02's Avatar
96 Lt1's are MAF not speed density, correct? In that case I would also look at cleaning the MAF sensor, changing the fuel filter. Considering it has some engine mods, I would look into a fuel pressure guage just for future issues.
I would also inspect the TB to make sure everthing is sealing properly. If it is ported some of the screws may have came loose. Truthfully, it sounds like a vacum leak since you are not getting an SES light. If you can borrow a TPS I would try that out also.
Old Nov 24, 2010 | 07:35 AM
speedZ28's Avatar
Man i have looked every and mean every where for a vacum leak cant find one this is really hurting my head i checked last nite for that vacum leak today ill do the tps and let u no thanks brother for the info
Old Nov 24, 2010 | 10:30 AM
redz_02's Avatar
Also, try cleaning the IAC, just be careful with it. Sorry about jumping around so much, just havn't worked on an LT1 in ages.
Lastly, fuel filter, and I would recommend installing an under hood fuel pressure guage. Helps alot in these situations.
Does it miss any when cruising once warm?
