v6 camaro work??
OP, you could jsut find the supercharger and related plenums and pulleys and bolt that on, last time I checked LKQ had the blower for $400, pulley it for $80 more and port it and you outta be doing good
You can't just bolt up a m90 supercharger from a GTP. They have different heads and wont just bolt on unless you swap everything above the heads. Way more money then $480. And really at that point just swap in a L67 and modify the supercharger to fit.
You obviously can't read, there are 2, 3800 motors which one are you talking about, the OP has a firebird which is the L36, you seem to be talking about the L67, they are different, please stop giving bad advice as you have no idea what you are talking about.
There are not really any aftermarket heads available except for ZZP's Aluminum heads which (bare and unported) cost almost the same as theirs and other companies stage 3 ported, big valve race heads.
Go with a good camshaft with a good lobe design. John at 60°Inclusive has access to some great cam profiles and can match a cam to your heads if he ports them for you. Great guy to deal with, did some quality work on my heads and intake.
If you want a basic off the shelf grind, Abbott has one of the best NA cams.
Need bigger valve springs, 105# minimum but probably more along the lines of a 130# set, new timing chain, etc.
Companies that I just think of right off the top of my head that offer ported heads for the L36/L67.
60°Inclusive
ZZP
Intense
Abbott
Super Six Motorsports
Your friend have headers yet? He won't see the full benefit of the build unless he's running headers. Is this an automatic or 5 speed manual? He'll need access to somebody that can tune the car PROPERLY!
Here's a look at my heads that were worked on by John.
Before they went out to him:
