Car self destruct ..
Old Dec 24, 2010 | 11:51 PM
ex-SS-ve's Avatar
Hows oil pressure? Let me know if your still at a loss for what it is.
Old Dec 25, 2010 | 01:07 AM
v8sten's Avatar
^^^^^^^ what joe said ^^^^^^^
pull the oil filter off and cut it open and look for sparkly stuff in the filter, that would be bearing material ......... bad
I can cut the filter open for you if you dont know how, plus i have the tool to do it.
Old Dec 25, 2010 | 01:58 AM
Anthony Williams's Avatar
Sound like my old LS1 after 2 flattend cam lobes.
Old Dec 25, 2010 | 02:18 AM
StreetSilverado's Avatar
Curious about the oil pressure too. Like said about check out the filter and cut it apart. If thats not it then I guess you could make sure one of the EGR provisions on the headers isn't broke or leaking.
So many different things can make a knock like that. Could be real bad or just one of those things that just made your butt pucker because you "thought" it was real bad and it turn out to be something simple
Old Dec 25, 2010 | 02:30 AM
ex-SS-ve's Avatar
as for simple stuff cant tell you how many times someones told me " man i fucked my car up" its knocking / tapping . and i go look at the headers and one of the tubes is cracked, the egr provision has came apart and all it needed was some welding work.
Old Dec 25, 2010 | 03:34 PM
kp483's Avatar
Oil pressure was fine yesterday when driving it.. Guess ima have to wait til monday to get it up on a rack to check for leaks. Thanks all! All input is helping! Happy Holidays guys! and ladies
Old Dec 25, 2010 | 08:11 PM
the black02's Avatar
Default noise
check lifters could b a bad lifter. the lifter could have gone bad and ur losing the opening and closing of the valves. thats y ur getting the stuttering and lost of performance.
Old Dec 25, 2010 | 08:43 PM
madmike9396's Avatar
deff the header bearings went out !!!
lol idk man good luck hope its just exhaust leak
Old Dec 25, 2010 | 09:07 PM
kp483's Avatar
When i pulled the valve covers we knocked the engine and movement on all eight
Old Dec 26, 2010 | 05:01 PM
Busy Mopper's Avatar
rod bearing, sorry.
Old Dec 26, 2010 | 09:47 PM
kp483's Avatar
Well, hopefully tomorrow i'll have a lead and keep you guys posted!
Old Dec 27, 2010 | 12:36 AM
  #32
Devil Bird's Avatar
I bet you a dollar that you have a hole in one of your primaries on you passenger side header.
Post up what is wrong with it when you find out.
Old Dec 27, 2010 | 08:08 PM
  #33
kp483's Avatar
Paypal the $1clam?
Okay guys, after having to drive it to work.. there was a second outlook this time when the valve covers were pulled... Problem was found. I would like to thank everybody for the help, and hopefully I have helped somebody out with a similar problem!
Whats left of the PATRIOT GOLD!
Whats left of the factory ROCKER!
Old Dec 27, 2010 | 09:50 PM
  #34
ex-SS-ve's Avatar
One of the reasons i stay away from patriot and k motion valve springs. Things are garbage. You got lucky that the valve locks didnt fall off and let that valve trash your motor.
Old Dec 27, 2010 | 09:53 PM
  #35
kp483's Avatar
Yep.. thankful for dual valvesprings nonetheless.. Any suggestions on new springs??? cam in sig
Old Dec 27, 2010 | 10:45 PM
  #36
Texhotrod593's Avatar
ISKY or PAC gets my vote
Old Dec 27, 2010 | 10:57 PM
  #37
ex-SS-ve's Avatar
Some crane 832s or a manley equivalent. Running the manleys on mine. Dont remember the number but ive put about 30k miles on them and theyve been great.
Old Dec 27, 2010 | 11:40 PM
  #38
westtexasbuff's Avatar
Yup, same thing happened to me a while back with comp 918s. I've heard from a very reputable friend that most springs are made by the same manufacturer, and then bought by companies and slapped with a brand on them. Take that for what it's worth, I'm not sure if it's true. I'm running Patriot Golds, have been for 7K miles (rough miles haha), and no issues. How many miles did you have on this set?
Old Dec 28, 2010 | 09:59 PM
  #39
kp483's Avatar
Yea.. still looking into what springs to get and if i should keep factory rockers or not.. Just fixed the pics above, didnt realize i posted the same pic twice.
Old Dec 28, 2010 | 10:06 PM
  #40
enigmah's Avatar
Yeah... was gonna say.. An exhaust leak thats effects performance that bad?? Come on guys. Glad you found the problem man!
