In need of some info from you LS guru's!!
I'm build a 6.0 stock crank ls3 heads.. My deals is I want to run the mahle pistons with a scat "I" beam stock replacement rod.. Small pin with ether set up 6.125 or 6.100 rod piston.. My deal is I can't find the right part numbers to get my motor going!!
The part# I got is (piston# L92314030F04) (rod# 26125716)
But my motor build tells me that set up will stick out the hole .013 so I'm lost.. I've called a few people and thats the same numbers everyone gives me..
The motor build is going to be.. Hoping for 550hp?
6.0 block 30 over.. Torque plate hone all ARP bolts
LS3 heads cut 30 to 64cc pack 650 lift springs
Cam??? Still up in the air lol
LS7 lifters
Intake?? LS3 or L92 truck?? Need help on that
Mahle pistons file fit rings
Scat rods floating pins
1 7/8 headers
LS7 lifters
1 7/8 headers
Give the head shop a call they built mine 713 947 3335. We used Mahel pistons , scat 4.00" crank, 6.125 rods. My bore is different due to the block. On LS motors the pistons due stick out of the bore. I'm not sure how much. You have to have valve reliefs for the bigger LS3 valves.
