is this possible?
Old Jan 6, 2011 | 10:21 AM
unlimitedpcs's Avatar
Default is this possible?
is it possible to put 15w40 engine oil on a gasoline engine? its mostly used on diesel trucks. just want to know your thoughts and inputs.
Old Jan 6, 2011 | 11:30 AM
94fixerTA's Avatar
Yeah. It's possible. How bad is your motor knocking?
Old Jan 6, 2011 | 11:34 AM
redz_02's Avatar
Why the need? The only big difference is the cold weight.
Old Jan 6, 2011 | 11:36 AM
i just heard that it was good for high mileage cars. motor doesn't knock or anything. motor has 162k and running.
Old Jan 6, 2011 | 11:58 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
If your oil pressure is still good, I would see no reason to run the thicker (cold) old in there.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jan 6, 2011 | 01:22 PM
redz_02's Avatar
Stick with the normal weight. You need to worry more about oil pressure than the cold weight of your oil.
Old Jan 6, 2011 | 01:40 PM
jb7241986's Avatar
Run high mileage oil.....end of story...
Old Jan 6, 2011 | 02:32 PM
cambirdracing's Avatar
I have 289,000 on my 3.4 v-6 and run 5w30 High mileage Valvoline in it. It has over 60 psi anything over idle. About 45 at idle.
Old Jan 6, 2011 | 03:09 PM
jb7241986's Avatar
hell yeah i agree with you cam
