Need opinion for a tbss
Old Feb 2, 2011 | 09:17 PM
LSX-coupe's Avatar
Default Need opinion for a tbss
Looking for around 750 rwhp in a tbss. How easy would it be with a 418 ls3 with a tvs2300. Built rpm transmission. I know the drive train eats power being a 14 bolt with 4:10 gears factory. Any ideas?
Old Feb 2, 2011 | 09:58 PM
luvmeZ28's Avatar
This isn't to make fun of granatelli is it?
Old Feb 2, 2011 | 10:00 PM
FlashWS6's Avatar
Destroyer of Exotics
Lmr did 1 a few months back. Heads,cam,tvs2300 on a 416 stroker with spray. Might wanna call them and see what kinda numbers it put down.
Old Feb 3, 2011 | 07:18 AM
LSX-coupe's Avatar
Anybody know what it made off nitrous. Link would help. Don't wanna bug those guys. Just stacking up a few ideas.
Old Feb 3, 2011 | 01:41 PM
Dirty 30's Avatar
Dyno Queen?
Old Feb 3, 2011 | 02:40 PM
westtexasbuff's Avatar
403, L92s, and twin mp76s.
http://s282.photobucket.com/albums/k...105_222055.mp4
http://s282.photobucket.com/albums/k...105_230757.mp4
http://s282.photobucket.com/albums/k...105_205231.mp4
Old Feb 3, 2011 | 02:47 PM
MY06TBSS's Avatar
I am makin about that on pump gas ...a little more on c16....
Old Feb 3, 2011 | 07:22 PM
LSX-coupe's Avatar
PURPLE minivan is fast as ****.
Old Feb 3, 2011 | 07:36 PM
BT03mach-1's Avatar
spray will fix anything! if that don't work spray more!
Old Feb 3, 2011 | 08:57 PM
LSX-coupe's Avatar
I used to have the same mentality.
Old Feb 3, 2011 | 10:30 PM
charlie_gonzales's Avatar
Is your tbss a 2wd or all wheel drive? What tranny is in it...4l80e? I know you mentioned it was built, just didn't know what came in them. How much power do you lose thru the drivetrain with the 14 bolt, compared to other rear ends I wonder? What do you think at least a grand at the crank will get you the 750 to the ground, depending on the drivetrain in your ride?
I figure 14 bolt, 4.10s, AWD(2WD-not as much) plus the built auto would equal to a major drivetrain loss in power
Old Feb 4, 2011 | 11:25 AM
bwooten492's Avatar
Warhawk and a F2!!!
Old Feb 4, 2011 | 01:02 PM
LSX-coupe's Avatar
Built rpm level 7 4l70. I figure around a solid 20% drivetrain loss. Its 2wd and i might pull 4.10's out put a 3.73 gear in it. Just some ideas im toying with. i figured 900fwhp to be 720rwhp. Should be more than enough. It will be drove everyday but for only 20-30 minutes a day total. I only live 5 minutes to work.
Old Feb 4, 2011 | 02:02 PM
Omega Doom's Avatar
I like your style!
Old Feb 4, 2011 | 02:08 PM
Oh ok I was thinking conservatively (1000) with the parts that drain the most...AWD with 4.10s instead of the 2wd...I was thinkin 25% loss just to be safe to get your goal
Should be a kick *** ride none the less
