vibration at high speed - where to go from here
Check your build dates on the tires before you go on that long trip!
When you see those long pieces of tread of a tire on the highway with steel belts in them, they started as seperation then the tread ply's came off the tire.
Here's another thing to think about if you have plenty of tread left.
Have your tires "trued". They put it on what looks like a modified balancer and do the lathe trick to the tread surface. It removes a small amount of rubber.
I didn't really believe in this till one of my customers got a new set of tires on his Z. He brought it by my shop before trueing. Felt fine. I told him it would be a waste of money.....
He drove it for 1k miles (set the rubber) and had them trued then brought it back. The difference was UNBELIEVABLE. It was like it was on lazers or something. He also said it was usually worth 5-10 K more tread life due to the more even wearing on the tread surface.
Made a believer out of me.....
That's pretty cool, ninja. Where did he go to get that done?
After all the stuff that can go wrong with tires, I'm thinking about doing the Flintstone stone wheel mod
